351 Mustang
460 BBF
Old May 25, 2006 | 09:17 PM
bottlebaby's Avatar
bottlebaby
Default 460 BBF
anyone in this forum running a 460......?
Old May 25, 2006 | 11:12 PM
92BOOSTED's Avatar
92BOOSTED
Default RE: 460 BBF
My friend and i have put together 3 of them, what do you need to know?
Old May 25, 2006 | 11:19 PM
bottlebaby's Avatar
bottlebaby
Default RE: 460 BBF
where you able to run power steering with any of them.......
if so...
did you change the pulley ?
run everything serp belt and change water pump to run reverse ?
how did you do it.....i know that you have to use the mustang pump cause they are higher pressure....
i miss power steering....
let me know what you did......
thanks in advance.....
Old May 26, 2006 | 12:20 AM
myshifter's Avatar
myshifter
I ♥ Acer
Default RE: 460 BBF
I been running them for 10 years, I use a manual flaming river rack, but I run what many would consider barely streetable trim
Old May 26, 2006 | 06:51 AM
92BOOSTED's Avatar
92BOOSTED
Default RE: 460 BBF
Yes, we still use the power steering. we swap the pulley to the V-belt style.
You do not have to go reverse on the water pump, it is a standard rotation.
If you can afford it i would recommend the flaming river manual swap as it works well and the engine compartment looks so much better.
We are looking by the way, for the serpentine setup from a newer truck so we can swap it.
Rye
Old May 26, 2006 | 08:30 PM
bottlebaby's Avatar
bottlebaby
Default RE: 460 BBF
thats cool.....i would really like to have power steering again.....amera-cruise is coming to town this year again and i would really like to do some crusing that weekend.....
on that manual rack has anyone tried the quick ratio setup ?
Old May 27, 2006 | 05:08 PM
myshifter's Avatar
myshifter
I ♥ Acer
Default RE: 460 BBF
ORIGINAL: bottlebaby
ya I use them, I runnny a skinny front tire though and its no different without PS
Old May 27, 2006 | 10:50 PM
bottlebaby's Avatar
bottlebaby
Default RE: 460 BBF
that will work......i also run the moroso skinnys (3.5) up front.....are you running the quick ratio or the standard ratio ??
Old May 28, 2006 | 04:29 AM
myshifter's Avatar
myshifter
I ♥ Acer
Default RE: 460 BBF
quick and my steering was great
Old May 28, 2006 | 11:14 AM
bottlebaby's Avatar
bottlebaby
Default RE: 460 BBF
thats what i need then......thanks !!
