351 Mustang
351W -> 393 Stroker
Old Jul 5, 2006 | 11:19 PM
ckyguy68's Avatar
ckyguy68
Default 351W -> 393 Stroker
Ive heard that a 351W can be made into a 393 stroker by simply putting in 302 pistons and a different crank. True? And if so, would it be a bad idea to get a 351W from a junkyard? I am thinking about doing something like this if possible.
Old Jul 5, 2006 | 11:27 PM
88ragtop's Avatar
88ragtop
Default RE: 351W -> 392 Stroker
Yes thats true, and a very good idea too. I have my 351 block already just sitting in the garage but Im still undecided on which stroker kit(displacement) I want to go with.
Old Jul 5, 2006 | 11:36 PM
ckyguy68's Avatar
ckyguy68
where did you get your block? how do you feel about junkyard engines? i would replace the crank, pistons, heads, intake, etc.
Old Jul 5, 2006 | 11:38 PM
myshifter's Avatar
myshifter
I ♥ Acer
393 uses a 3.85 crank, stock length 351 rod and stock compression height 302 piston
Old Jul 5, 2006 | 11:41 PM
ckyguy68's Avatar
ckyguy68
yes, this is what i was thinking about. what power numbers would we be looking at for that setup with AFR 185s and a carb? and with efi and typical bolt ons?
ORIGINAL: myshifter
wildcobrar's Avatar
wildcobrar
Totally correct. That is the exact basis of the Ford Racing 393 short block and long block they sell. It also does not require any notching on the block to clearance the added throw of the crankshaft.
ORIGINAL: myshifter
Old Jul 7, 2006 | 09:06 PM
wildcobrar's Avatar
wildcobrar
With the right cam, those AFR 185 heads and a Vic Jr intake with a 750 carb will make 500HP at flywheel at 6000 rpm or less. Just research it and be fussy with the details of the build.
Old Aug 4, 2006 | 09:38 PM
bosscougar's Avatar
bosscougar
youll need to have the 351w block bored .30 over and add .30 over 302 pistons. I had to notch my piston skirts to clear but im allmost done with it ,,new here so if you have allready been told this ,, my bad
guitarman376
Sep 30, 2015 05:54 PM
LiquidDrink
Sep 29, 2015 10:06 AM
Brett Ludlow
Sep 23, 2015 06:59 AM
EASTIDEE123
Sep 14, 2015 03:52 PM
YoungStangsMan
Sep 5, 2015 07:01 PM
