351W Block Weight
Does anyone know how much a 351W block weighs? Also, if possible the dimensions. I need an answer ASAP so if anyone could help it would be greatly appreciated. THANKS!
Dan B.
Dan B.
This should help
GENERAL ENGINE DATA
CID Bore/Stroke Year Mfg Bore Spacing
221 3.5 x 2.87 62,63 4.38
260 3.8 x 2.87 62-65 4.38
289 4 x 2.87 63-68 4.38
302 4 x 3 68- 4.38
351W 4 x 3.5 69-80+ 4.38
351C 4 x 3.5 70-73 4.38
351M 4 x 3.5 75-80+ 4.38
400 4 x 4 71-80+ 4.38
429 4.36x 3.59 68-72 4.90
460 4.36 x 3.85 68-80+ 4.90
ENGINE DIMENSIONS
Engine Width Length Height Weight Notations
221
255
260
289
302
24 29 27 1/2 460
Boss 302 24 1/2 29 28 1/2 500
351W 25 29 29 525
351C
Boss 351C 25 1/2 29 1/4 29 550
351M
400 26 29 1/2
29 575
332
352
360
361
390
406
410
427
428
27 32 29 625
427SOHC 32 34 30 680
429-460 27 34 30 720
BOss 429 30 34 30 635
4.6 SOHC * 26.9 28.6 600 *28 w/o oil cooler, 29 w/oil cooler
4.6 DOHC 28.9 27.1 29.8 576
CRANKSHAFt PART NUMEBRS AND DATA (BASE PART# 6303)
CID Year ID Stroke Main Rod Material
221 260 289 62-68 C2OZ
C3OZ
1M
1MA 2.87 2.2486 2.1232 Cast Iron
289HP 63-67 1M 2.87 2.4286 2.1232 High Nodular Iron, last counterweight may be polished for hardness test. May have orange paint swatch
302 68-69 C8AZ-A 2M 3.00 2.2486 2.1232 Cast Iron
302 70-74 C8AZ-A
2M
2MA 3.00 2.2486 2.12322
302 75-78 2M
Boss 302 69-70 D0ZE-A
7FE-B 3.00 2.2486 2.1232 Forged steel, 69 is crossdrilled
351W 69-72 3M
3C 3.5 3.0000 2.3110
351W 73-79 3MA 3.5 3.0000 2.3110
351C 70-74 4M
4MA 3.5 2.749 2.311 Boss and HO have Brinell hardness test mark located on a polished conuterweight
351M 75-80 1K 3.5 3.000 2.311
400 71-80 5M
5MA
5MAB 4.0 3.000 2.311
429 68-78 4U
4UA 3.59 3.00 2.5
460 68-78 2Y
2YA
2YAB
2YABC 3.85 3.000 2.500
460 79- 3Y 3.85 3.000 2.500
CONNECTING ROD PART NUMBERS AND DATA (BASE PART # 6200)
Part# CID Weight(grams) Length Bolt Material
C20Z--A
C3AZ--D 221/260
260/289 521-533 5.1545 5/16 Broached bolt seat
C9ZZ--B 289HP
302 Boss 581-593 5.1545 3/8 Spot Faced bolt seat
D10Z--A 302 557-569 5.090 5/16 "Standard Duty"
D0AZ--A 351C 688-700 5.778 3/8 Marked DOAE-A on beam
D1ZZ--A 351C Boss 688-700 5.778 3/8 Marked D1ZX-AA, shotpeened, magnafluxed, 180K psi bolts
D1AZ-A 400 846-858 6.58 3/8
-P.
GENERAL ENGINE DATA
302 4 x 3 68- 4.38
ENGINE DIMENSIONS
221
255
260
289
302
24 29 27 1/2 460
351W 25 29 29 525
351C
351M
400 26 29 1/2
29 575
332
352
360
361
390
406
410
427
428
27 32 29 625
C3OZ
1M
302 70-74 C8AZ-A
2M
302 75-78 2M
351W 69-72 3M
351C 70-74 4M
400 71-80 5M
5MA
429 68-78 4U
4UA 3.59 3.00 2.5
460 68-78 2Y
2YA
2YAB
C20Z--A
C3AZ--D 221/260
C9ZZ--B 289HP
-P.
Hey, I also seen somewhere that it weighs 525 lbs but I believe thats the entire motor. Im just looking to the block weight. Do you think the w/h/l is just the block or the entire motor?
Well than do you know how much a 302 weighs?
BTW, I am trying to get all of this information because I need to contact USPS about shipping prices and I need to know the weight and dimensions.
