351 Mustang
Calculating compression ratio?
Old Aug 31, 2006 | 04:22 PM
Rorin67's Avatar
Rorin67
Default Calculating compression ratio?
Is it possible to calculate a motor's compression ratio with only the following:
Compression testing results in roughly 170 average for each cylinder (range 165 to 176).
Engine is 351W, stock stroke, bored .030 over.
Do I need more info than that?
Many thanks in advance.
Old Sep 1, 2006 | 07:00 PM
r.barn's Avatar
r.barn
Default RE: Calculating compression ratio?
Compression you are talking about is just a leak test to test cylinder seal.
To calculate compression ratio you need to know:
cylinder bore
stroke length
head gasket bore diameter
head gasket compressed thickness
Cylinder head combustion chamber size
Piston dish or dome volume
Piston deck clearance.
Whats your engine combo, and I can type info into calculator and give you
relatively close number.
Piston deck clearance we'll have to take an educated guess since you have to tear down engine to get that.
baddog671
Jul 26, 2016 01:20 PM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
bconboy
Sep 21, 2015 12:52 PM
uberstang1
Sep 20, 2015 06:42 PM
rocky321
Sep 15, 2015 10:00 AM
