351 Mustang
351C install
Old Oct 23, 2006 | 08:12 PM
creeper's Avatar
creeper
Default 351C install
I will be aquiring a 351 Cleveland from a 71 mach 1 mustang. The engine is prime, dyno'd at 355 horsepower and 408 torque. Has anyone or does anyone know a website that will have the list of parts to install this into my 91 'stang. I also will probably be using a C6 for the tranny.
Old Oct 23, 2006 | 09:20 PM
Cleeman99's Avatar
Cleeman99
Default RE: 351C install
u will have to aquire some strong motor mounts that will have to be located unless it a 5.0L already u might get it to bolt up with out and mods but u'll need sub-frame connectors k Braces and i beefed up c6 tranny because i stock is goos for 300-320Hp most likly fail when u put the boots to it and prob new tranmisson mounts
Old Nov 12, 2006 | 02:06 AM
LCC's Avatar
LCC
convertable 5.0 motor mounts will work perfect for your aplication. For the tranny, if the 351C came with a C6 then your torq plate will work with a C4 and AOD. You will have no roblems with any of these for holding the power. The AOD will have to set up with a TV cable for a carb set up and its not hard to setup. This is assunming you want a automatic..
Old Dec 12, 2006 | 04:48 PM
atomsk680's Avatar
atomsk680
or you want a manual a Tremec will be best, a t5 will break under that torque
the 5.0 motor mounts should work fine,
mtgldr
Feb 3, 2024 09:00 PM
BOBCATJACK
Sep 14, 2015 02:18 AM
Sep 10, 2015 08:39 PM
