351 Mustang
351w roller conversion
Old May 10, 2007 | 12:25 AM
90mustang5.8's Avatar
90mustang5.8
I ♥ Acer
Default 351w roller conversion
i want to run a Hydraulic Roller Tappet camshaft from Trick Flow
so all i would need is lifters, roller rockers, and the roller cam pretty much or??
this a stock block remember, try and work with me here lol...im 15 so i still dont understand alot lol.
Old May 10, 2007 | 02:53 AM
89Ford's Avatar
89Ford
Default RE: 351w roller conversion
ORIGINAL: 90mustang5.0
yea, clearly
it depends on what year block you have. and im not positive but i dont think roller rocks are relative to using a roller cam
Old May 10, 2007 | 03:19 AM
90mustang5.8
I ♥ Acer
now im hella confused lol...................i founda guy on this site that coverted hes 351 to a roller i'll just pm him a hah.
Old May 10, 2007 | 02:19 PM
r.barn's Avatar
r.barn
1st. do NOT use a trickflow "302" cam on a 351
long stroke Ford small blocks require different valve timing then a 302 cam.
get a custom cam.
2nd: you can use roller cam, but you have to use the $400-500
conversion lifters that are linked
I decided to just spend that $400-500 on a roller cam block
and save myself a lot of trouble.
Its one of those 6 up or half dozen down things.
spend the money on a more expensive roller cam block
or spend same money on expensive conversion lifters.
Old May 10, 2007 | 05:01 PM
atomsk680's Avatar
atomsk680
just get a lunati or comp cams cam and lifter kit. your going to need the guideplates for the pushrods and lifters, unless they are included, i am not sure. roller rockers are not relative to the roller cam, they are a nie add on, but not necessary, although it just seems to go withit
Old May 10, 2007 | 08:07 PM
Arrid Extra Dry's Avatar
Arrid Extra Dry
http://www.compcams.com/technical/Ca...6-07/52-55.pdf
scroll down to the bottom left of page 55
Old May 10, 2007 | 08:15 PM
90mustang5.8
I ♥ Acer
ORIGINAL: r.barn
get a custom cam.
trickflow makes351 cams...................................... http://store.summitracing.com/egnsea...=KeywordSearch
Old May 11, 2007 | 02:33 AM
Force4's Avatar
Force4
when they state small block there initiating a 302 not a 351.
Old May 11, 2007 | 03:11 AM
90mustang5.8
I ♥ Acer
i may just run a comp cam, but would that be a good h/c/i combo with the trick flow track heat heads and the edelbrock performer air gap intake/?
Old May 11, 2007 | 03:18 AM
Force4's Avatar
Force4
i have the basic Eelbrock cam/intake setup and its proving to work very effectivly. I have no personal experience with Comp though so i couldnt tell ya
