500hp 351, need clutch info
RE: 500hp 351, need clutch
ORIGINAL: davidssvo
thats a good idea for the motor mounts i'll look into that.
i guess i'll go with a spec stage 2 and see how that holds up
if anything it only takes me a couple hours to swap it out if it lets go
Stage 2+
(that reads... Stage two plus)
it means, call brenspeed... www.brenspeed.com
and ask for a price on a Spec Stage Two Plus clutch kit
David, before buying a clutch you should call spec. Give them your combo and they will be able to give you a better idea of what you need. And Adder the reason I don't post alot over here is because keyboard racers like yourself get personal when there opinion isn't taken like the word of god.
ORIGINAL: AdderMk2
thats funny....
stage2+ would be MORE than enough
ORIGINAL: S351R13
Spec Stg 4 clutch if you plan on taking it to the track and running on slicks. If street tires and very little track use a centerforce dual friction or a Spec stg 3 will do fine.
go for the 2+... its $315 on brenspeed
