351 Mustang
351W
Old Jul 18, 2007 | 10:00 AM
pathall26's Avatar
pathall26
Default 351W
I can get a free 351W out of a wrecked 96 E250 Van. Just wondering if it is at all possible to put that into a 91 Lx? if so, are there any special mods needed?
Old Jul 18, 2007 | 10:09 AM
92civy's Avatar
92civy
Default RE: 351W
oh yes get it, its for free. and i am pretty sure its a roller block. i plan on this same swap. look in the 351 section ^^^ above and see how the swap is. in there at the top you will find the "5.8 conversion" thread.
https://mustangforums.com/m_1121694/tm.htm
http://www.fast351.com/cartech/351w.htm
http://www.freewebs.com/vristang/fox351wswapfaq.htm
check these out and read alll the thread. they are great.
Old Jul 19, 2007 | 01:27 PM
pathall26's Avatar
pathall26
Default RE: 351W
I will have access to the entire motor, do i need to pull the obd II system or what?
Old Jul 19, 2007 | 02:59 PM
my77stang's Avatar
my77stang
Default RE: 351W
dayum, free 351w roller motors FTMFW!
Old Jul 20, 2007 | 09:12 AM
pathall26's Avatar
pathall26
Default RE: 351W
yes, the van belongs to the company that i work for and it has 119,000 miles on it. so i'm trying to get ahold of the motor. what tranny should i use?
Old Jul 20, 2007 | 10:19 AM
r.barn's Avatar
r.barn
Default RE: 351W
drop it in.
You will need to upgrade heads, cam, intake and headers though to see big power.
your stock computer will run it fine.
stock trans will last for a while, but upgraded 351 can definitely break it.
Old Jul 20, 2007 | 03:06 PM
pathall26's Avatar
pathall26
Default RE: 351W
I was thinking of upgrading my h/c/i on my 5.0 anyway, so instead i am thinking of doing it to the 351 while it is in between vehicles. could i be looking at close to 400 rwhp with that?
Old Jul 20, 2007 | 04:20 PM
Mike93SVT's Avatar
Mike93SVT
Default RE: 351W
easily. that's the same motor i've got. it's a roller and used stock 92 electronics to run it. just need a different distributor to use your computer. with some high flow heads like afr 205's or 225's and a good cam and intake you'll make near 400.
guitarman376
Sep 30, 2015 05:54 PM
LiquidDrink
Sep 29, 2015 10:06 AM
FoxGT
Jul 11, 2004 11:49 PM
Mustang88LXKid
Feb 29, 2004 08:01 PM
WNDSOR
Jan 30, 2004 09:47 AM
