351 Mustang
just got my 418W
Old Jul 25, 2007 | 09:35 PM
76stangalang87's Avatar
76stangalang87
Default just got my 418W
Last week I bought a 93' LX to make a bad street car out of. This week I traded my mustang II for a 418W. I remember most of whats done to it but hes emailing me the flow numbers and cam card and stuff. But it has 4340 forged crank and rods, JE flat top flycut pistons, Aluminum heads (i cant remeber namebrand) but they have been ported to outflow AFR 225 heads, 1.72 roller rockers, Custom grind solid roller cam 727/721 lift 260 something duration I'll post the specifics when I get the info. Also has a super victor intaske port matched to the heads, 850 holley carb, he had it all built at a shop in Easley SC. The builders said it should make around 680 at the motor at 7500rpm. Here's a link to the pics http://s157.photobucket.com/albums/t...18Wstroker.jpg I'm gonna post pics as i build it theres also pics of the car on there
Old Jul 25, 2007 | 09:51 PM
Mike93SVT's Avatar
Mike93SVT
Default RE: just got my 418W
sounds good, but you may want to step up to a 950 carb. that 850 won't support 680 hp. good luck
Old Jul 25, 2007 | 11:17 PM
76stangalang87
thanks.
Old Jul 26, 2007 | 04:10 PM
68CSTANG's Avatar
68CSTANG
Im not saying that Mike93SVTiswrong but I would imagine that carb would be fine. Who knows until you try it out. I just may be too conservative because Im used to seeing people around here buyin the biggest cam, carb, heads and so forth for their stock 283. Like I said the carb may be too small but I would try it out before you buy another one. Just my $.02
Old Jul 26, 2007 | 09:57 PM
Arrid Extra Dry's Avatar
Arrid Extra Dry
i agree with mike, carb is too small.
Quick Fuel Q-Series Carburetors - summitracing.com
Blake Carburetion
i have a quickfuel and a blake carb.
both run better than any bg or holley ive ever had.
i recomend at least a 950 for that set up
Old Jul 27, 2007 | 09:40 PM
Matt Paul's Avatar
Matt Paul
I would run a prosystemscarb.They will custom make you a carb to match your heads, cam, intake and trans.It is cheaper then a BG or a Holly Hp.I run one and my cam is just as big as yours, and my carb only needed to be 785cfm and Iamgoing 132 MPH in the 1/4 on only 362 CI.
Thanks Matt Paul
P.S. Just so you know they are the manufactuers of the Worlds Fasts Carbs.If you go racing just look at the big boys Hot street, Pure Street Carsjust an example.
cshmny
Sep 29, 2009 11:57 PM
68fastback_lover
Jul 29, 2008 10:18 PM
HYPEracing
351 Mustang
Mar 5, 2008 07:25 PM
sean_stanghopeful
Mar 5, 2008 11:45 AM
sarpicaste
Mustang Videos
Sep 11, 2006 12:04 AM
