Strongest 351W Block
RE: Strongest 351W Block
I always have and am currently building on an aftermarket 4blt main block. However, I personally know someone who is running the fastest N/A TFS "R" headed car in the country on a 1970 block. Est 750rwhp on the spray. So it can be done, but it is still only a matter of time. You can still have a lot of potential for main cap movement even with a girdle, basically even with stronger webbing, if your caps walk or even one walks and you move a main bearing your going to have issues. Just my feelings on the subject after about 15 Windsor builds.
ORIGINAL: MadMan@TheWheel
Thanks Matt Paul
ORIGINAL: Matt Paul
Who is this person you talk of with the 1970s block making 750rwhp?You also state that it was on the hose what is it on motor?I run a 1994 roller block with a inline valve headand make 621rwhp N/A and have over 250 passes on it this year alone.I would like to talk to him because its seems we are making about the same power with a early cast block and with a newer cast block.MadMan you seam pretty smart on the subject andI would like to talk to you also, Ive been building windsors since I put the fisrt one in my 1982 GT back in1989.Talk about a head ache there were no conversions for those cars at all 18yrs ago compared to now a days.
Thanks Matt Paul
Thanks Matt Paul
Matt what heads were you running? compresson ratio? custom solid roller? drag car or weekend warrior?
ORIGINAL: 92civy
have you picked up that 69 block yet? and did you get a pictures of the roller block and 69 block together?
ORIGINAL: Jasperstang308
mad man is that out of the box tfs "R" heads?
ORIGINAL: Matt Paul
Thanks Matt Paul
Thanks Matt Paul
Thanks MattPaul
