351 Fox Oil Pan
RE: 351 Fox Oil Pan
ORIGINAL: 89Ford
where'd you get that info? Your ***?
ORIGINAL: USMCrebel
any oil pan from a 302 or 351w should work, i dont know about the clevelands .
USMCrebel, dont speak if you dont know the real answer. 351 in a fox requires a special oil pan to fit. you can't just use any pan.
RE: 351 Fox Oil Pan
i have heard so many different setups for the pan and motor mounts. i would like to hear from some people who have actually installed a 351. what motor mounts and oil pan did you use and how much of a cowl hood did you need. also is your car efi or carb.
i will be getting my car sprayed in the coming weeks and would like to have it spray and trim a hood for me while he is doing some work and i would hate to get a 2 inch hood or any kind of hood and have it not be enough. or on the flip side not even being able to need a aftermarket one.
RE: 351 Fox Oil Pan
I just did the 351W swap into my 86. I kept the stock crossmember setup. I'm using some Solid motor mounts that I picked up off ebay. And I purchased the FRP 351W Swap pan. I had to buy a cowell hood to get it to clear, but it all worked out nicely.
