351 Mustang
just got a 351w differences?
Old Aug 13, 2007 | 10:50 AM
x6x6x7x's Avatar
x6x6x7x
Default just got a 351w differences?
came out of an 80 something box van is there any differences in the years that they made them
Old Aug 13, 2007 | 11:04 AM
AdderMk2's Avatar
AdderMk2
Banned
Default RE: just got a 351w differences?
https://mustangforums.com/m_3617604/tm.htm
anything after 74 is a waste. the 75+ blocks had a thin main web, and inferior metal composition.
you should try to get one thats a bit older... like 69-74
Old Aug 13, 2007 | 12:29 PM
w8less's Avatar
w8less
although i think 75+ had one piece rear main seals
Old Aug 13, 2007 | 02:11 PM
WhiteWindsor's Avatar
WhiteWindsor
Anything after 74 is not a waste. 71-79 were pretty much the same block, but regardless it is still stronger than a 302. Jasper i have a 78 351 block that was a 2 piece rear main, i say was because i had it machined for a one piece. I am not really sure when they converted to a one piece.
Old Aug 14, 2007 | 12:21 AM
w8less's Avatar
w8less
ORIGINAL: FASTBLACK
what did it run you to have it machined and what are the benefits of 1 piece rear main seals?
Old Aug 14, 2007 | 07:04 AM
MadMan@TheWheel's Avatar
MadMan@TheWheel
I
Old Aug 14, 2007 | 10:01 PM
89Ford's Avatar
89Ford
i think they are less prone to leak and are easier to change
Old Aug 15, 2007 | 07:46 AM
WhiteWindsor
The machine work to convert to a one piece cost $125. Yes, they are less prone to leaking and are easier to change. With a one piece you just drop your tranny. With a 2 piece you have either drop your tranny and raise your engine so you can drop oil pan or just unbolt tranny and pull motor.
Old Aug 21, 2007 | 10:29 PM
Hurricanedt77's Avatar
Hurricanedt77
I just went through a rear main seal dilema with my 84 351W. Go with a 1 piece, or have the block machinened to accept it.
Dokilar
15
Oct 16, 2015 08:13 PM
guitarman376
Sep 30, 2015 05:54 PM
UrS4
Sep 30, 2015 10:13 AM
mrappe
Sep 26, 2015 10:16 AM
