351 Mustang
Ford Torque Specs.
Old Oct 31, 2007 | 07:08 AM
MadMan@TheWheel's Avatar
MadMan@TheWheel
Default Ford Torque Specs.
I do not think I have seen this in the tech section, if it is I apologize. This is very helpful information for new engine builders, and again could cut back on the repeat threads.
These specs are for stock-type bolts with light engine oil applied to the threads and the underside of the bolt head. Moly and other lubes offer reduced friction and increased bolt tension, which will affect the torque figure. If you use aftermarket performance bolts like ARP's, you should follow the recommended torque specifications.
260, 289, 302
Fastener Type Torque Spec
Main cap bolts 60-70 ft.-lbs.
Outer main cap bolts, 35-40 ft.-lbs.
Connecting rod bolts 19-24 ft.-lbs. (40-45 ft.-lbs. for 289 HP Boss 302)
Cylinder head bolts 65-72 ft.-lbs.
Rocker arms 17-23 ft.-lbs.
Intake manifold bolts 23-25 ft.-lbs.
Oil pump bolt 23-28 ft.-lbs.
Cam bolts 40-45 ft.-lbs.
Cam thrust plate bolts 8-10 ft.-lbs.
Harmonic damper bolts 70-90 ft.-lbs.
Flywheel/flexplate bolts 75-85 ft.-lbs.
Pressure plate bolts 35 ft.-lbs.
Front cover bolts 12-15 ft.-lbs.
351W
Fastener Type Torque Specs
Main cap bolts 95-105 ft.-lbs.
Connecting rod bolts 40-45 ft.-lbs.
Cylinder head bolts 90-100 ft.-lbs.
Harmonic damper bolt 70-90 ft.-lbs.
351C, 351M
Connecting rod bolts 40-45 ft.-lbs. (45-50 ft.-lbs. for Boss 351C)
Cylinder head bolts
(follow factory torque sequence) 105 ft.-lbs. (125 ft.-lbs. for Boss 351C)
Rocker arms (non-adjustable) 18-22 ft.-lbs.
5/16 in. intake manifold bolts 21-25 ft.-lbs.
3/8 in. intake manifold bolts 28-33 ft.-lbs.
Oil pump bolt 25 ft.-lbs.
Cam thrust plate bolts 9-12 ft.-lbs.
Front cover bolts 12-18 ft.-lbs.
429-460
Maincap bolts 95-105 ft.-lbs.
Cylinder head bolts 140 ft.-lbs.
Intake manifold bolts 25-30 ft.-lbs.
360, 390, 406, 427, 428 FE
Crossbolts for 406 and 427 40 ft.-lbs.
Connecting rod bolts 40-45 ft.-lbs. (53-58 ft.-lbs. for 406 and 427)
Cylinder head bolts 80-90 ft.-lbs. (100-110 ft.-lbs. for 1963-67 427)
Rocker arm shaft bolts 40-45 ft.-lbs.
Intake manifold bolts 32-35 ft.-lbs.
Oil pump bolt 12-15 ft.-lbs.
Now that my fingers are worn totally out, I hope this is helpful
MadMan
Old Oct 31, 2007 | 11:00 AM
bighungrymatt's Avatar
bighungrymatt
Default RE: Ford Torque Specs.
very good info, adding to my favorites
Old Oct 31, 2007 | 11:47 AM
MadMan@TheWheel
Lol, thank you. I am wanting them to make it a tech sticky, so everyone can use it.
Old Oct 31, 2007 | 01:36 PM
bighungrymatt
Im sure one of the moderators will once they see it
Old Oct 31, 2007 | 02:28 PM
HC_CrAzYHoRsE's Avatar
HC_CrAzYHoRsE
done deal, nice work Madman[sm=smiley20.gif]
Cavedawg
Sep 17, 2015 09:51 AM
Black_GT_02
Aug 20, 2015 01:26 PM
WDScott
Aug 17, 2015 06:38 AM
ccwebb
Aug 11, 2015 06:47 PM
dfw692
Aug 7, 2015 11:53 PM
