Help! Car will not start!!!
Ok boys and girls, my 89'GT with a fresh motor will turn over fine but will not start! I checked and I have fire if I pull the spout connector out but not with it in. I am getting fuel to the injectors because I have fuel pressure, but they are not pulsing. I tried an inj. pulse light and no worky. What do you think? Bad ECU? I have a new fuel pump, injectors, regulator, rails, etc. I can hear the pump come on when I turn the key on to prime, but the injectors are not pulsing. I have all ready replaced a shorted ingition switch as well and checked my relays. Any ideas? I am about ready to pull my hair out on this one!!![/align]
RE: Help! Car will not start!!!
Check all your fuses. My stang had a TON of electrical hack in it. Bad ign switch shorted a bunch of crap out, burned up some wires. I'm not sure if the ignition sys controls the injectors or not.
I'm not sure either? I all ready checked the fuse box and only had 1 blown fuse. It was the one that ran the interior light and a couple other things inside. I replaced it and it is still good. However, After initially replacing the ign. switch, It still wants to keep cranking after I turn the key switch off. It makes me wonder if I still have an issue there or if it is the clutch safety switch? I have sincereplaced the pig tail plug in to the ign. switch because there was2-3 singed wires at the harness end. This didn't help anything either. Any other ideas?
I checked the computer ground, chasis ground and HEGO grounds. all were hooked up. Are there more? I have also tried a new computer. No luck. I'm not sure if the 5.0 has a CPS sensor or not. Iwas thinking it didn't? I thought about just carbing the car, but all ready have everything set up EFI and hate to have to change it all up again and spend more $! I know it's going to be something simple if I could just find it. I'm about ready to push it off in a lake some where. I put over $6000 in this motorand can't even hear it run. Bummer.
92 5.0stang
08-13-2015 06:46 AM
Milan Dragway
08-12-2015 03:43 PM
