351 Mustang
351c help?
Old Nov 21, 2007 | 05:56 AM
mach1noob's Avatar
mach1noob
Default 351c help?
i just bought a 71 mach 1 with a 351c, and dontknow where to start. i what to end up with 400-500whp. where do i start and what do i begin with?any info well help, thanks
Old Nov 25, 2007 | 10:09 AM
92cobra's Avatar
92cobra
Default RE: 351c help?
whats your budget?
Old Nov 26, 2007 | 07:52 PM
68CSTANG's Avatar
68CSTANG
If it has 4 barrel heads, keep them. I made good power with the stockers with just a 3 angle job and diff. springs when I switched to a Crane cam. I dont think aftermarket heads are worth the $$ other than aluminum heads obviously being lighter.
Old Dec 1, 2007 | 04:08 AM
mach1noob's Avatar
mach1noob
my budget is around 6g, and its a two barrel,
Old Dec 11, 2007 | 03:15 AM
atomsk680's Avatar
atomsk680
what i did was a larger cam, i have a lunati bracket master II, the i have a weiand x-celerator single plane intake, longtube hookers comp, then bigger gears and a bigger stall, thats what i have so far, im supposed to eb around the 380 range but i havnt had a dyno yet
Old Dec 12, 2007 | 11:17 AM
irish1's Avatar
irish1
There are many ways to reach your goal, 4v heads, aussie 2v heads, assuming the bottom end of the motor is good I would simply have it gone through and leave it stock aside from getting better pistons. If you go the 4V route make sure they are closed chamber, nothing wrong with OC but it is harder to find pistons to make some compression.I found a bare set for 200, once you have heads, I would call someone like Jay Allen and have a chat with him, tell him how fast you want to spend and he will make you a great cam and either sell you, or recommend what supporting bits would work well. You will need to replace the stock valve in the heads, they are two piece and like to come apart with expensive consequences. Roller valve train, good intake and a well matched carb, just that will put you at your goal no induction needed.
mustangheaven
Jan 3, 2016 11:20 AM
mustangheaven
Oct 7, 2015 10:23 AM
mustangheaven
Sep 29, 2015 11:00 AM
S'PortMustang69
Aug 30, 2015 08:27 PM
73Cleveland
Oct 23, 2005 05:32 PM
