351 Mustang
initial fuel pressure and timing
Old Jan 2, 2008 | 10:26 PM
mustang35190's Avatar
mustang35190
Default initial fuel pressure and timing
Hey guys whats up, getting the 351w finished first time with this engine, was wondering
what initial fuel pressure and timing should I set just after the first start-up, 351w .30over
AFR 185 heads, 10.5-1 compression, trick flow R upper and lower 75mm throttle body, 42lb injectors,
MSD pro billet distributor, 10.4mm wires etc etc, anything to get me in the ball park thanks.
Old Jan 2, 2008 | 11:06 PM
WhiteWindsor's Avatar
WhiteWindsor
Default RE: initial fuel pressure and timing
I cant help you with fuel pressure, i'm carbed. My engine is 11.1 and my dizzy is locked out at 33 degree's timing. You can probably run a little higher, maybe 35-37. Total timing should be in at about 2500-3000 rpms and then you can adjust initial timing accordingly. Start with 15 and see where your at.
Old Jan 5, 2008 | 09:32 PM
Indy's Avatar
Indy
Yeah, me too... Can't help you with the fuel pressure cause I'm carbed as well. Sorry. But I also am running around 11:1 compression and a 15 degree initial timing (vaccum advance line disconnected) gives me a great start-up on the motor. My total advance is 36 degrees all in at about 3000 revs.without any pings!
Indy
Old Jan 14, 2008 | 03:18 AM
P.S.I.cho's Avatar
P.S.I.cho
fuel pressure should be whats specified for the fuel injectors to properly opperate, FRPP states all their flow rates are ran at 39.15 psi, To convert to a delta pressure of 43.5 psi, multiply flow rate by 1.054. so if u need more fuel run 43.5 if your not lean run 39.15, for timing id start at 10-12* advance and work your way up from there
mstahoo
SVT Forums
Aug 19, 2021 09:15 PM
MEISTERSNFB
Mar 31, 2020 07:50 AM
Scottyboy187
SVT Forums
Sep 2, 2015 10:12 AM
timeformiller44
Aug 26, 2015 12:03 PM
MXBT187
Aug 20, 2015 02:36 AM
