Fuel issues... any ideas?!
Finally put the car on the road after a long time.
have ported and polished heads, with full exhaust, JLT CAI, SCT livewire. not to much
Was getting lean codes. bank 1 and 2, checked fuel pressure, was ####, so replaced the pump with a Ford GT 255lph pump. wired it in and such, now at Higher RPMS, i lose fuel, big time, like 10psi at 5300rpm, also corraltes with the voltage higher voltages, less fuel pressure, i have it datalogged if anyone wants to see it, i can send the file, i am clueless, i know there are no kinked lines anywhere, checked multiple times, newer filter. and i doubt its in the tune for something so drastic of a drop in pressure.
either new pump is failing, or i have the wiring backwards and the polarity is killing pressure when seeing voltage spike.
but my car should be running fast than a 9 in the 1/8 because it has before, now i am running 10's and slower.......
jaiidutch
Sep 14, 2015 10:29 AM
tramphardrocker
Sep 13, 2015 08:56 PM
