351 Mustang
motor notching?
Old Jan 7, 2008 | 11:29 AM
Force4's Avatar
Force4
Default motor notching?
Anyone know how much it would cost to get a motor notched?
Old Jan 7, 2008 | 01:06 PM
cccharleston's Avatar
cccharleston
Default RE: motor notching?
Are you talking about clearanced for a stroker? If so about $100 while its at the machine shop for tanking, boring, yada
Paul
Old Jan 7, 2008 | 04:51 PM
92civy's Avatar
92civy
Yes if your talking about clearance for a stroker, It costs about 100! I will let you know what I run into then I go to put my 4" (408) stroker cran in. I will most likely have to cut the corner off, right where the oil pump is. But I will be doing the clearance myself. Its easy!
Old Jan 7, 2008 | 10:19 PM
psuhillbilly150's Avatar
psuhillbilly150
yeah i would save the money you only need to do that corner near the oil pump, die grinder and 5 minutes and your set.
Old Jan 8, 2008 | 05:19 AM
92civy's Avatar
92civy
Yep pretty much! not a whole lot of trouble with 408's!
Old Jan 8, 2008 | 09:04 PM
Force4's Avatar
Force4
I am buying new heads for my motor and apparently they require me to notch the motor. I am not familiar with notching so your input is a + ! Thanks
Old Jan 8, 2008 | 10:35 PM
92civy's Avatar
92civy
Oh you mean notching the piston??? For PTV clearance? What heads?
firehorse02
Nov 16, 2015 11:28 AM
UrS4
Oct 3, 2015 06:23 AM
Explosive
Oct 2, 2015 07:45 AM
Drastang
Sep 30, 2015 03:48 AM
logan409
Sep 26, 2015 07:43 PM
