351 Mustang
engine combo help roller 351
Old Jan 11, 2008 | 04:53 PM
65nova's Avatar
65nova
Default engine combo help roller 351
So i have a 89 notch that im planning on doing a 351w swap to
I know im going to go carb because the main harness is missing out of the car (its a roller project)
i plan on putting a c4 behind it
but i have a roller 351w that i plan on either keeping it a 351 or just going 357
The plan:
get the stock crank turned if needed
forged I beam rods or forged stock replacement
forged pistons (aiming for 9.5 or 10:1 compression)
as far as that im not sure what i should do for h/c/i
i was looking at the 200cc RSH cast iron heads other that that i dont know what i should do?
let me know what you guys think
Old Jan 11, 2008 | 05:44 PM
S351R13's Avatar
S351R13
Default RE: engine combo help roller 351
For your combo I would just keep the stock rods. The I beams don't offer much more. I have never broke a rod. I have bent one before. I have also ben I beams. I wouldn't use iron heads. I would invest in either a set of GT40 Z heads or a nice trick flow. 10 to 1 compression would be great for the street.
Old Jan 14, 2008 | 03:12 AM
P.S.I.cho's Avatar
P.S.I.cho
ya for a street car the upgraded rods shouldnt be nessicary, ya trick flow heads will perform well, or you can get a set of top line heads fairly cheap these days, for cams just look for the descriptions, your gonna want a powerband to approx 6500 RPM im assuming, with fair idle qualitys, id stick with 230 duration or less, and without flycut pistons might wanna watch the lift too
Nick Oliver
Oct 17, 2018 04:22 AM
SSRFUZZY
Members Other Vehicles
Jan 6, 2016 08:22 PM
mmarsh3014
Wheels & Tires
Oct 20, 2015 09:08 AM
Ryan Fitzpatrick
Sep 14, 2015 02:21 AM
Pyrate Dave
Sep 10, 2015 07:30 PM
