351 Mustang
question
Old Apr 8, 2008 | 10:22 PM
wmustanggt's Avatar
wmustanggt
Default question
Heres the thing i got a 93 lx that started with a 4 banger , then converted to a carbed 302 , now i am wanting to put a carbed 351 windsor in it with a c6 trans out of a 83 model ford truck my question is what will i need to change to do this swap ? Any advice appreciated
Old Apr 8, 2008 | 11:35 PM
woodsy's Avatar
woodsy
Default RE: question
headers, oil pan, intake, distributor, certainly dump the c6 unless you dont mind beating the trans tunnel with a sledgehammer.
Old Apr 9, 2008 | 11:59 AM
351mustang's Avatar
351mustang
actually i think the c6 will fit...but im not sure if a c6 will bolt up behind a 351w...unless ur 351w block is a bigger...because i had a c6 tranny and was gonna put it behin my 351w and it was way to big..it came of a 351m (a bigger 351 block)
i could be wrong tho..there could be bigger or smaller 351w that will bolt up a c6
Old Apr 9, 2008 | 03:12 PM
89Ford's Avatar
89Ford
ORIGINAL: 351mustang
dump the c6 weighs alot and wont be needed
no there is no different size 351 windsors(excluding deck height?) the bell patern for a 289 302 and 351 windsor all share the same bellhouse paterns. not sure but the c6's might come in different bolt paterns. that would make the most sense
OP, you wont have to change much but you may want to upgrade some things. Fuel systems might be one of those things to look into, but it will depend on how much power you plan on. you'll need a swap oil pan, swap headers and a swap accessories bracket for power steering and a/c
Old Apr 9, 2008 | 09:55 PM
thunderjet429's Avatar
thunderjet429
WELL, a 351w,351c,302,289, and even 300 6cyl all have the same bell pattern... now a 351m,400m,429, and 460 all have the same bell pattern so that's why your C6 didn't work... a C6 will fit without tunnel mods i have put one behind a 429 and a 351w in mustangs without mods, BUT if you can get a C4.. the C6 IS ROUGHLY A 30 H.P. HANDICAP TO A C4. unless you have a 300 hp + motor a C4 will be fine BUT go over that with some tires and suspension that will hook up and a stock C4 will break ben there done that[:@]. a c6 will hold more power yes but sucks power to.
Old Apr 11, 2008 | 02:41 PM
wmustanggt's Avatar
wmustanggt
Thanks for you alls info! the reason i want to go with a c6 is cause i want to beef up the 351 abit possibly a strocker kit ,or super charger ,but will the cross member be the same as a c4 crossmember? Thanks for the info in advance
Old Apr 11, 2008 | 04:40 PM
projectresto83's Avatar
projectresto83
M.A.D. Motorsports
Even with a built 351 drop the c6. It is heavy, bulky, and a parasite. Put a little money into a built c4 and have at it.
On the bolt pattern, don't forget the 232 v6 also has the same pattern.
Old Apr 12, 2008 | 12:10 AM
wmustanggt's Avatar
wmustanggt
The more i think about it the more i want a c4 but how much do yall think i should ask for a c6 with a shift kit and a TCI stall converter the converter is 1 step up from stock
Old Apr 12, 2008 | 07:33 AM
projectresto83
M.A.D. Motorsports
Depends on how much you have in it. At least that plus little more. Clean it up and throw on a nice clean coat of paint and you wil prolly get a little more for it. It would be nice for someone who is building a big block.
Old Apr 12, 2008 | 03:27 PM
wmustanggt's Avatar
wmustanggt
sounds good thanks!
Dokilar
15
Oct 16, 2015 08:13 PM
AMAlexLazarus
AmericanMuscle.com
Oct 2, 2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 10:29 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
treesloth
Sep 28, 2015 07:03 AM
