351 Mustang
351???
Old Apr 25, 2008 | 11:14 AM
PureEvilfox666's Avatar
PureEvilfox666
Default 351???
Possibly thinking of picking up a 351, if i decide to go that route what should i get it out of/what year? Thanks in advance.
Old Apr 25, 2008 | 03:30 PM
kweb288's Avatar
kweb288
Default RE: 351???
94-95 ish ford truck of somesort....pretty much an kind of truck will have the 351 in it up to that year. (i think 96 is when they switched to the modular....could be wrong though) but those early 90's engines are efi so its easier to put in, unless you are planning on going on a carb set up.
Old Apr 25, 2008 | 08:00 PM
92civy's Avatar
92civy
Default RE: 351???
Out of all honesty, I would say get a 69-70. But Those are going to be very hard to find. Also the roller blocks started in 94+, many say the 92 lightning was roller capable but not from the factory.
Old Apr 26, 2008 | 02:24 PM
woodsy's Avatar
woodsy
Default RE: 351???
ORIGINAL: 92civy
94-97 roller blocks, good luck finding a 69-70, and yes the lightnings came with a hyd flat tappet cam in a roller block
Old Apr 27, 2008 | 12:21 PM
PureEvilfox666
Default RE: 351???
What kind of HP numbers do you guys think i could see with a 94+ 351 motor, with hci and long tubes?
Old Apr 27, 2008 | 01:52 PM
kweb288's Avatar
kweb288
Default RE: 351???
5000000000000 hp........ all depends on what kind of hci, you get, wether or not the parts are adequitly matched up to one another, there are SOOOO many variables
Old Apr 27, 2008 | 02:29 PM
89Ford's Avatar
89Ford
Default RE: 351???
ORIGINAL: kweb288
what kweb means is pick a hp# and then you pick the parts to achieve those numbers. HCI could be anything, there is like a million combinations, with all different hp outputs.
SSRFUZZY
Members Other Vehicles
Jan 6, 2016 08:22 PM
teeeeg67
Sep 1, 2015 11:53 PM
steelers743
Aug 31, 2015 07:16 AM
Mustangs of Illinois
Aug 22, 2015 10:00 PM
89blueslug
Aug 10, 2015 07:20 AM
