351 Mustang
New Build Overheating
Old Jul 10, 2008 | 02:12 PM
90hatch351's Avatar
90hatch351
Default New Build Overheating
I just finished snapping the engine back together on my 351W. I am battling an overheating issue. The themostatand head gaskets are installedthe right way, timing isn't quite set yet. I seem to have air pockets in the coolant system. I was told tojack the car up and refill the radiator, which I didm and itwas low. It seems to still have air pockets. What is the best way to get rid of them?
What temperature should I be looking for as normal? Also, what are you guys setting your timing at?
Old Jul 14, 2008 | 10:22 AM
90hatch351's Avatar
90hatch351
Default RE: New Build Overheating
I threw a coolant overflow in this weekend and tried my best to bleed the air out of the system. I found a hex nut in the return line from the heater core where it goes into the intake and loosened it until coolant came out. I also threw some Water Wet in with the coolant. Seems to be working well. It hasn't run hotter than 190 since and stays around 180 degrees.
BOB ROME
Jul 26, 2023 01:54 PM
svfetter
Oct 5, 2015 11:39 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
the5
Sep 19, 2015 06:13 PM
MusicCity615
Sep 12, 2015 07:05 AM
