351 Mustang
351 Distributor
Old Feb 26, 2009 | 03:02 PM
alecracing's Avatar
alecracing
Default 351 Distributor
is different than a 302, right????
If i want to upgrade, what kind of choices do I have?
Old Feb 26, 2009 | 06:39 PM
uedlose's Avatar
uedlose
yes it is different. MSD and such make good aftermarket ones
Old Feb 27, 2009 | 06:34 AM
alecracing's Avatar
alecracing
I found a guy with this one for sale
MSD PRO BILLET DISTRIBUTOR P/N# 8455
he says it will work in a 351 but all the info I see say it won't...what's the difference between them.
Old Feb 27, 2009 | 07:53 PM
Modfox5.8's Avatar
Modfox5.8
I run an MSD Pro Billet, I believe the part number may be similar to the one you typed above. I'll verify tomorrow AM, and get back to you. One thing you NEED to know is that the gears on the distributor will vary weather you have a Roller or a Flat Tappet 351W.
With that said, what year 351W is it?
I'm not sure what material roller/ flat tappet cams call for but I know 100% that they ARE different. If you look at the sticky's you will see a post from VRIStang. I believe that he goes into some detail about what you will need.
Old Feb 27, 2009 | 07:55 PM
Modfox5.8's Avatar
Modfox5.8
The 351W Distributor has a longer shaft and also the part that rests in the intake manifold is thicker than that of a 302.
Old Mar 14, 2009 | 12:06 AM
decipha's Avatar
decipha
modfox you have a PM concerning your experiences with the msd pro billet dis
Old Mar 15, 2009 | 12:54 PM
alecracing's Avatar
alecracing
I don't know what year the engine is but it iS a roller cam
Old May 28, 2009 | 05:00 PM
jaymotor's Avatar
jaymotor
There is one on ebay for $98 made in china of course. Not sure of the quality, but just wanted to throw it out there. It's for an efi setup, says 94 and up but I'm sure it will fit older engines converted over. I would like to know if anyone is using one?
bradleyb
Nov 27, 2015 07:50 PM
bradleyb
California Regional Chapter
Oct 1, 2015 01:02 AM
StalkerGT
Sep 25, 2015 02:41 PM
dalehunter
Sep 25, 2015 10:51 AM
jaiidutch
Sep 14, 2015 10:29 AM
