351 Mustang
dizzy problem
Old Apr 15, 2009 | 03:37 PM
worm2500's Avatar
worm2500
Default dizzy problem
heres the problem
i finally get around to putting my engine together and notice that my MSD distributor (model MSD-8580) has clearence issues with my victor jr intake. it looks to me as if the diameter of the housing is to big. it turns out MSD makes a special dizzy that is supposed to be used with a Vic Jr (model MSD-85805). does anyone in here use a vic jr carburator intake? if so, what dizzy do you guys use. I also have an MSD ignition box so it must be compatable with that. what do you guys think of this distributor http://store.summitracing.com/partde...DisplayPrice|0 do you think it will have the same clearance problems as the MSD one.
question two... what type of gear is needed with a solid roller cam? I am guessing steel, but i could be wrong.
Old Apr 18, 2009 | 02:37 PM
worm2500's Avatar
worm2500
Default vacuum or mechanical advance distributor?
after doing some research i found that a solid roller cam needs a bronze or polymer gear.
but now i need help on deciding what distributor to buy. what works with a vic jr intake? what type of advance do i want, mechanical or vacuum? i plan on racing, but also crusing on the weekends. any help would be great.
Old Apr 19, 2009 | 10:24 AM
projectresto83's Avatar
projectresto83
M.A.D. Motorsports
You can just grind down the intake a little to get the clearance you need.
Seanam
Oct 4, 2015 10:15 AM
mdj89
Sep 23, 2015 08:49 AM
kachuy10
Sep 22, 2015 01:27 PM
stangin1996gt
Sep 21, 2015 11:01 AM
Big Al's 03
Mach 1 Section
Sep 21, 2015 07:59 AM
