351 Mustang
Push rods seem loose. Maybe I'm crazy?
Old May 21, 2009 | 04:10 PM
brianbooth's Avatar
brianbooth
Originally Posted by cccharleston
Sounds like you have to much preload on the rockers causing the valve to stay open. Did you soak or manually fill the lifters berore installation? You should readjust the preload on all of you rockers.
I soaked 'em in oil before putting them in so they really should be fine. As for the preload, they're all torqued to spec. I'm clearly no expert on these engines, but I was under the impression that the 351W is supposed to be torqued (17-23 pounds) rather than doing the zero lash + half turn method.
Old May 21, 2009 | 08:03 PM
cccharleston's Avatar
cccharleston
I forgot you had stock stuff. I am no expert with those rockers but it sounds as if you need shims.
Old May 22, 2009 | 02:16 PM
brianbooth's Avatar
brianbooth
Well a new set of lifters did the trick. I figured that since the preload was off one way before they got pumped up and off the other way after, they were the common denominator. It sure sucked having the pull the intake off that thing after it was in the van
Bokeo
Oct 10, 2015 08:28 PM
jrrhd73must
Oct 2, 2015 09:17 PM
UrS4
Sep 30, 2015 10:13 AM
mustangheaven
Sep 29, 2015 11:00 AM
Sixer4Life
Sep 28, 2015 07:05 AM
