351 Mustang
need info
Old May 10, 2009 | 12:17 AM
USMCrebel's Avatar
USMCrebel
Mach I Section Moderator
Default need info
what are the block strengths of the 351's
what are the rod strengths
and what are the piston strengths
searched for hours found plenty of block info but jack on rods and pistons.
Old May 10, 2009 | 06:59 AM
cccharleston's Avatar
cccharleston
What year? If you are going to make enough power to worry about the block I'm sure you will need a new rotating assembly.
Old May 10, 2009 | 09:26 AM
USMCrebel's Avatar
USMCrebel
lol i won't be worrying about the block, i'm not building anything that badass, just looking at using some turbo's on a stock rotating assembly no more than 575-600hp crank that is, and maybe more for track days. this will be a DIY JY project as there are plenty of cheap turbos from them that can feed CFM's needed to feed a stock shortblock 351w
Old May 10, 2009 | 01:46 PM
psuhillbilly150's Avatar
psuhillbilly150
your gonna need to change the pistons to a much lower compression number like 8 to 1 or 8.5 to 1 for the boost. While your doing that at least put in a set of I beam rods if not H beam rods or else you are going to make pieces. You may get away with a stock cast crank if you keep your rpms under 6500 or so.
Doing that sort of power on a stock bottom end is asking for it. my bud runs a 351w in his truck that he upped the compression and put new heads and all that on it but left the internals alone. Took it to a truck pull and he stretched every one of his rods and ruined the motor. Now that may be a bit heavier load then what your mustang is gonna see but at the track everyone always pushes their equipment a little harder.
Also from what I have read around here the safety limit on a stock block is about 600 horses.
Old May 10, 2009 | 09:09 PM
USMCrebel's Avatar
USMCrebel
what is the limit on the rods, but anyone that says the limit on the 351 block is 600rwhp is full of it...we have a guy here making 750 before the 200 progressive shot and he runs 5.90s @ 121 in the 1/8th the block is a 94 block
Old May 11, 2009 | 05:29 AM
302army187's Avatar
302army187
replace the piston's, the rod's can take it, or so ive heard.
seen plenty of guy's running stock rod's with 150shot
Old May 11, 2009 | 10:53 AM
USMCrebel's Avatar
USMCrebel
thats what im seeing is a bunch of guys just changing out to the trw pistons and then they're able to run 6-700rwhp.
any ideas on the best el cheapo forged pistons?
Old May 11, 2009 | 11:28 AM
TopNotch89's Avatar
TopNotch89
not to hijack this thread or anything....along the same lines as the OP....so if you rebuilt (new rings, honed, bearings, gaskets, etc.) a 351 with stock rotating assembly and fitting it with a good H/C/I combo with higher compression...could this be a good alternative to making power besides boost or stroking?
Old May 11, 2009 | 11:35 AM
USMCrebel's Avatar
USMCrebel
i think boost would net you better results and mileage
Old May 11, 2009 | 12:00 PM
302army187's Avatar
302army187
there's plenty of proven 351w combo's that are VERY mild and net 380+ horse power to the wheel. There's also WILD combo's that arnt really streetable, putting out 600hp n/a with enough work.
my goal is 350 to the wheel, and a 150shot on top when i put in a 351w
