351 Mustang
5.8 conversion efi setup
Old Feb 9, 2010 | 06:32 PM
vic312's Avatar
vic312
Default 5.8 conversion efi setup
I'm going to be doing a 5.8 conversion, wondering if I would be able to use the same computer that is in my car any1 on here ever done it b4 plz let me know
Old Feb 9, 2010 | 07:01 PM
sn95_331_GT_ yellow's Avatar
sn95_331_GT_ yellow
yes, but you need a lot of other supporting mods.
Old Feb 9, 2010 | 07:21 PM
vic312's Avatar
vic312
Do you know of any websites that sell the stuff i will need?
Old Feb 9, 2010 | 07:24 PM
vic312's Avatar
vic312
I have a 1992 ford van with a 351, its in good running shape, would that big trans behind that 351 fit into my mustang?
Old Feb 10, 2010 | 07:22 AM
uedlose's Avatar
uedlose
What engine did your car start with? and what trans is in the Van. Also the 351 in a Mustang has been done a 1000s of times. You need to do some more searching.
Old Mar 3, 2010 | 05:51 PM
Venomantidote95's Avatar
Venomantidote95
Fairly simple, most parts will interchange, your intake will be different and the distributor, and i`m sure the van isnt roller so your distibutor will need the brass or bronze gear not the steel gear for a roller cam!
Your headers will be different also! it is most likely a c-6 trans and yeah it will fit like a c-4! may have to modify the crossmember for it!
basically intake headers distributor and you`ll be set! oh and prolly a different size serpentine belt! and the van prolly has a mech fuel pump so make a block off plate for the timing cover! you may need a 351 double sump pan kit from summit also! like 150$ for pan pickup and dipstick!
Old Mar 3, 2010 | 06:08 PM
sn95_331_GT_ yellow
1992 with a 3spd auto?...
its probably an E4OD trans, and there's NO WAY itll fit into the Mustangs trans tunnel... its a tight fit in the trucks and vans...
jwog666
Dec 27, 2021 08:09 PM
fastbackford351
Oct 1, 2015 12:24 PM
guitarman376
Sep 30, 2015 05:54 PM
Drastang
Sep 29, 2015 03:31 PM
