351 Mustang
351w combo
Old Apr 14, 2010 | 04:22 PM
95BOSS351W's Avatar
95BOSS351W
Default 351w combo
Would 400 rwhp be a bad assumption for this combo.351w bored .030 over.Trickflow twisted wedge heads that have been milled down making the compression ratio about 10.9:1 with flat top aluminum pistons. Trickflow stage 2 cam. Professional Products EFI Typhoon intake with 75mm t/b. BBK longtube headers o/r h-pipe and dyno tune. If you guys have any suggestions, please feel free 2 comment
Old Apr 14, 2010 | 05:07 PM
mustangmike_50's Avatar
mustangmike_50
400RWHP, may be a little high for that combo. I would suggest a better flowing intake, like a tfs R, or edelbrock victor junior efi, 24lb to 32lb injectors, 77 to 80mm mass air meter, 1 3/4" headers, 3" exhaust with either an H-pipe or a mac prochamber, at least a 225lph fuel pump, & 3.73 or higher rear end gears.
hope this helps
Old Apr 14, 2010 | 05:09 PM
stanks347's Avatar
stanks347
If you've dyno tuned why are you asking?
Old Apr 14, 2010 | 05:25 PM
minnow81469's Avatar
minnow81469
may because the op said he wants to get a tune! Hes asking if he'll hit 400 so he doesnt have to pay for a tune if he doesnt need it
Old Apr 14, 2010 | 05:33 PM
95BOSS351W's Avatar
95BOSS351W
well that is my current set-up without the tune. i actually have 42 lb/hr injectors for nitrous. and mustangmike_50 i have everything on ur list except a few things. Im actually running a 4:10 gear and i do currenlty have a 255lph fuel pump. SO roughly wat would would you guys estimate?
Old Apr 14, 2010 | 06:04 PM
TrimDrip's Avatar
TrimDrip
FudgeDrip
I think it would be close to 400.
I would look at a larger cam and porting the heads for upgrades. Would gain with a Victor Jr intake with an elbow too.
Old Apr 14, 2010 | 06:19 PM
95BOSS351W's Avatar
95BOSS351W
thats what i figured. Thnx man. i had a feeling that i would need 2 go bigger on the intake.
Old Apr 14, 2010 | 08:04 PM
TrimDrip's Avatar
TrimDrip
FudgeDrip
you can do some things with a windsor. There is a fella running one around here with a solid flat tappet cam, dome hyper pitons and ported 69 windsor heads with a small shot running 6.10s in the 1/8th. That was unheard of with the stock irons I thought.
Old Apr 14, 2010 | 09:15 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
please read, this is the 5.0 tech not 351 opinion section.,,,, thank you:
https://mustangforums.com/forum/5-0l...bers-read.html
Lethaldosage423
Oct 19, 2015 12:12 AM
Boostaddict
Lethal Performance
Oct 1, 2015 08:58 AM
Boostaddict
3.7L V6 S550 Tech 2015 - 2017
Oct 1, 2015 08:57 AM
guitarman376
Sep 30, 2015 05:54 PM
LiquidDrink
Sep 29, 2015 10:06 AM
