351 Mustang
Choices for valve springs
Old 09-09-2010, 05:44 PM
r390g
r390g's Avatar
Default Choices for valve springs
I got a 351 stroked to 427. Im using brodix 505 heads and I want to go with a comp cam with a 565 lift. What would be a good valve spring to use?
r390g is offline
Old 09-09-2010, 08:21 PM
wildcobrar
wildcobrar's Avatar
Not enough information to answer that question.
joe
wildcobrar is offline
Old 09-09-2010, 10:23 PM
r390g
r390g's Avatar
what other info would you need?
r390g is offline
Old 09-10-2010, 02:31 PM
wildcobrar
wildcobrar's Avatar
How about the cam part number?
Joe
Old 09-18-2010, 03:53 PM
r390g
r390g's Avatar
Comp cams xe282hr
r390g is offline
Old 09-19-2010, 08:49 AM
wildcobrar
wildcobrar's Avatar
Comp cams xe282hr
232/240@.050 and .565" in and .574"ex on a 112 lobe sep. Comp spring for that cam is a 986-16 or the premium spring is a 26986-16
986= 132#@1.750 inch and 293#@1.250inch coil bind is 1.150 inch and the dual spring is 1.430" diameter. Something with same characteristics and a little larger diameter spring will do well for you too.
Joe
Old 09-21-2010, 06:51 PM
sn95_331_GT_ yellow
sn95_331_GT_ yellow's Avatar
Comp cams xe282hr
way to under-cam that engine...
sn95_331_GT_ yellow is offline
GimpyHSHS
19
12-19-2023 01:12 PM
mrtrodonet
09-19-2020 03:12 PM
CS2007
06-25-2019 09:45 PM
mungodrums
09-28-2015 10:54 PM
Quick Reply: Choices for valve springs
