351 Mustang
replace with 351
Old Mar 8, 2011 | 06:46 PM
93 stallion's Avatar
93 stallion
Default replace with 351
Hi I need help deciding what to do. Don't have a ton of money but a little so let keep that in mind. I have a 93 mustang with a 302 and I took it to change the intake from a edelbrock performer to a trick flow r series its not acting right so I thought it needed a tune. When they checked the compression on one side two of the cylinders were low so now I need to rebuild my engine.
1) the car was not that bad before I dropped it off does any body know of what it could of happen
2) if im going to rebuild can I get a 351 w short block and put everything from my 302 cuz I got alot on it except on the short block and don't want to start all over again
Old Mar 9, 2011 | 04:00 PM
87Stallion's Avatar
87Stallion
lower intake wont work (351's are wider), youll need a different distributor. Heads will work but 351 blocks use 1/2 head bolts rather than 7/16. You will need different headers.
All your front accessories will bolt right up to the 351W. If you are short on cash Id just rebuild the 302.
5.0muscle
Jan 11, 2016 01:17 PM
SSRFUZZY
Members Other Vehicles
Jan 6, 2016 08:22 PM
9550
Oct 26, 2015 05:01 PM
MusicCity615
Sep 12, 2015 07:05 AM
Art161
Sep 9, 2015 10:33 AM
