351 Mustang
couple tech questions.
Old May 23, 2011 | 02:22 PM
blackngreenfox's Avatar
blackngreenfox
Default couple tech questions.
first off, anyone know how a f303 cam would do with a turbo? i hear alot about it being a good blower cam, but what about turbo?
next is the carb selction. its a 351w with a f303, and bbk unequal length headers and a victor jr intake. im thinkin around a 650? or so? (the carb will be changed when boost applied)
looking for opinions. maybe from someone who has done this setup?
thanks guys
Old May 23, 2011 | 06:23 PM
uedlose's Avatar
uedlose
I have not used a F-cam with a turbo but there is a guy on another turbo board named Brent Davis who made 800 + hp it may have been even more but it was a **** load. so yes they work well with turbos. He is not the only one there a good many guys on that board who have used the F cam with great success with a turbo.
Old May 23, 2011 | 06:48 PM
blackngreenfox
thanks man. im looking forward to boost. anyone know what a 351w will hold boost wise on stock internals. and i mean reliably not twice and then it blows haha.
Old May 24, 2011 | 07:54 AM
stangfreak09's Avatar
stangfreak09
i would say about 8psi for stock anything! thats just what i hear.
Old May 24, 2011 | 09:03 AM
blackngreenfox
i know my buddie ran around 8 pounds on a stock chevy 327. but i havent heard anything about a 351
Old May 25, 2011 | 06:03 AM
uedlose's Avatar
uedlose
I would not trust cast pistons to any boost. but that is me. other then the pistons the rest of the parts I would not be to worried about till the 500 hp mark then I would be changing out the rods for a better H beam or I beam there are plenty of guys that run the stock rods at high HP but I have seen to many W rods fail to trust them but they where in higher RPM NA motors also. the block and stock crank will hold lots of HP if done right.
As far as how much psi. they will hold. boost is just a measurement of restriction so low boost numbers on good flowing parts could be very high HP numbers compared to high boost numbers on parts that dont move air as good. so I dont put a bunch of faith in boost numbers. Turbos tend to be softer on parts so with a good tune the thinking is that you can make more HP on a given part then you could with N/A engine or a S/C engine with the same parts. I dont know if it is true or not.
Old May 25, 2011 | 09:30 AM
blackngreenfox
greatly appreciated man. very helpful. im thinkin it will get 8lbs with forged pistons and h beam rods and gt40 heads.
lovesilver
Members Mustangs
May 9, 2019 09:18 PM
patchshaffer
Tuner Central
Oct 5, 2015 02:24 PM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
treesloth
Sep 28, 2015 07:03 AM
