351 Mustang
The best 4 bolt cap kit?
Old Aug 12, 2012 | 09:51 PM
Venomantidote95's Avatar
Venomantidote95
Default The best 4 bolt cap kit?
In your opinions what is the best main cap upgrade?
I`m getting into a 421 cuin W build and will be doing a 4 bolt conversion on my 71 block, i wont be buying the cheap caps but dont want a set that would warrant buying an aftermarket block instead.
I wont be turning over 7500rpm, will be all forged internals with a dish top my setup will be 11:1cr, will still be EFI also.
The main point to this post is the best quality caps for around 200$ since the line bore and drill and tap will cost me about 425$
Thanks in advance for your usefull input!
I have a friend with a similar setup as to what i`ll be using but he went flat-top and he is about 12.6:1 with a solid cam, it`s in a mud truck so he used a 2 bolt main and has not had an issue but 300ft a pass it dosent matter much, mine will be a DD as i always have with a bit of nitrous when needed, that is the need for the cap conversion.....
Old Aug 22, 2012 | 01:16 PM
Venomantidote95
So i take it noone using a 351w has done the 4 bolt conversion then?
Old Aug 23, 2012 | 05:35 PM
Duncan_GT's Avatar
Duncan_GT
No one looks in the 351 section. Haha
Granatelli Sales
Mar 25, 2016 08:01 PM
Granatelli Sales
Dec 27, 2015 06:28 PM
maestro1024
Sep 21, 2015 02:40 PM
ernesto-619
Sep 10, 2015 01:32 AM
Boostaddict
Lethal Performance
Sep 8, 2015 09:56 PM
