427w engine build
Hey guys, I had my engine built a while back and planned on running a Vortech V7 on it. Now after getting the car put together and driving it here and there, I am having second thoughts. To my knowledge the motor is pretty tame/mild. Per the specs below, what would I need to do to get it in the 600hp range? Would i have to do a lot? The car already has a water methanol kit that was intended for the blower, so I could raise the CR with no problems I hope. Btw, it is a street car that will see some track time but not much. Any help is appreciate.
Engine:
- Block: Dart SHP 4 bolt main 351W stroked
- Crankshaft: Scat 4340 Forged Cleveland
- Connecting rods: Molnar 6.250 billet
- Pistons: Ross (new)
- Rings: Total Seal (new)
- Support rails and locks: Ross (new)
- Heads: AFR 220 Renegade heads, 58CC 2.10/1.57 (used)
- Head studs: ARP (new)
- Rockers: T&D shaft mount (new)
- Gaskets: Fel-Pro (new)
- Push rods: Smith Brothers 3/8 7.5 (new)
- Lifters: Ford hydraulic (new)
- Camshaft: Custom Ground Camshafts (new)
- Intake: Edelbrock Victor 5.8L (new)
- Throttle body: Accufab 90mm (new)
- Water pump: Edelbrock (new)
- Oil pan: Moroso 7 quart (used)
- Oil pump: Melling high volume (new)
- Dyno tested at 536hp and 524ftlbs
- Compression ratio: 10.2:1
Block 431
-Bore - 4.1505
-Piston size - 4.147
-Clearance - 0.0035
Main Register
-Crank Pin - 2.7488
-Main Bearing - 2.7506
-Clearance - 0.0018
Rod Register - 2.2249
-Rod Pin - 2.0998
-Rod Bearing - 0.1233
-Clearance - 0.0018
Writ Pin - 0.927
-Rod Small End - 0.9275
-Piston Pin Hole - 0.9275
-Clearance - 0.0005
Ring Size
-Compression - 0.023
-Second - 0.017
-Oil Ring - 0.015
Main Torque Spec - 110 w/moly
Rod Torque Spec - 70 w/moly
Balance Sheet
-Rod Rotating 441
-Rod Reciprocating - 143
-Piston & Pin - 682
-2% Overbalance
-Total Bob Weight - 1426.674
-Pistons - Ross custom dished 4.150 66509b
-Rings - Total seal CR0690 35
-Crank Shaft - 4340 Forged Steel
-Maine Bearings - ACL Perfromance 12-1010H
-Rods - Molnar 6.200 H beam w/ ARP 2000 Bolts
-Rod Bearings - ACL Performance 663H
-Cam - Cam Motion Custom Grind
-Hydraulic Roller grd# XA242-380-250-370-15
-Core 3490037
-Duration AT .05 IN
-Intake
-rocker ratio - 1.6 Lash 23 24 25
-Exhaust
- rocker ratio 1.6 Lash 23 24 25
-Intake/Exhaust
- Lobe seperation 115.1 CAM DEG, valve overlap 16.4 CRANK DEG
-Intake
- valve open - 11.1 BTDC, Centerline 111.1 ATDC valve closed - 51.5 ABDC,
Duration - 242.5 Crank Deg lobe lift - .38 IN, Valve lift - .608 IN, lobe area - 31.03 IN DEG
-Exhaust
- valve open - 64.6 BBDC, Centerline 119.1 BTDC, valve closed - 5.4 ATDC, Duration - 250 CRANK DEG, lobe lift - .37012 IN, Valve lift - .59219 IN, lobe area - 31.57 IN DEG
-Ford Racing
-Cam bearings - Dura Bond Coated F-1T
-Timing Set - Engine Pro (Cloyes) billet double roller
-Oil Pump - Melling High volume
-Cylinder Heads - AFR 228 Renegade
Engine:
Block 431
-Bore - 4.1505
-Clearance - 0.0035
Main Register
-Crank Pin - 2.7488
-Clearance - 0.0018
-Rod Pin - 2.0998
-Clearance - 0.0018
Writ Pin - 0.927
-Clearance - 0.0005
Ring Size
-Second - 0.017
-Oil Ring - 0.015
Balance Sheet
-Rod Rotating 441
-Piston & Pin - 682
-2% Overbalance
-Core 3490037
-Duration AT .05 IN
-Intake
-Exhaust
-Intake/Exhaust
-Intake
-Exhaust
-Ford Racing
Based on your description, you might not be happy until you're approaching 4 digit territory. That, or you're not putting the power down effectively, and so you're not feeling the full grunt of the torque when you step on it.
I would recommend finding locals who have also built their mustang, and see if you can find one of those two scenarios and ask for a ride along to figure out what your car is lacking. Shouldn't be too hard to find someone pushing high HP, or someone with decent hp, and upgraded suspension/drivetrain. After a few ride along butt dynos you will know what yours is lacking.
Thanks C1Forged. Right now, the car will sputter/choke if i give it full throttle. That being said, it definitely needs a tune. I think the fuel system combo I have isn't working well on a NA motor intended for for a SC. I think the 120lbs injectors are throwing in too much fuel or it could be just the tune. It's tough because I have the blower but I think I'll be happier just cruising around NA. That being said, I'd like to get the full potential out of the motor I have.
Sputter/Choke is definitely a tuning issue, and the injectors should be fine, they just need to be dialed back a bit in their duty cycle. As for the Blower, I would still recommend installing it, as the benefits of a Supercharger is no lag, and so the power delivery will be linear and smooth like a N/A motor.
Hmmmm.......536hp/524trq = TAME ??? You either have serious personal issues or incredibly high expectations lol.
Seriously though, after the swap to EFI, has the car been back for a tune ? From the way it's running it's way off and I'd bet your drivability issues will disappear and you'll finally feel that 500+ ft/lbs.
Time for a dyno tune, then we'll see how happy you are.
Lol... I definitely have tuning issues. I still haven't felt the true power of this motor. I was just throwing around the idea of either getting the most out of my motor NA, or keeping the blower idea. Btw, if any of you are wanting to or know someone who wants to modify their SC bracket to fit perfectly on a 9.5 deck height block, the guy who did mine did an outstanding job. It fits all head and block holes, and fits under the hood. I think he said he would charge around $250 for the modification.
