351 Mustang
351w help
Old Jan 2, 2006 | 05:42 PM
Smokinrubber's Avatar
Smokinrubber
Default 351w help
i currently have a 393 that i just installed in a 94gt and im wondering if someone can give me some tips on the problems im gonna have with the computer......the new 393 has all new fuel injection ..jus wondering about how to set the computer up for a 351
Old Jan 2, 2006 | 07:58 PM
86stanggt's Avatar
86stanggt
Default RE: 351w help
it will be fine along as your firing order is the same as a 302HO
Old Jan 2, 2006 | 08:03 PM
mkspeed26's Avatar
mkspeed26
if u use a 302 HO cam in it u will be fine
Old Jan 2, 2006 | 08:19 PM
Smokinrubber
Thanx for the help guys ...im using a 544.hydraulic lift flat tappet cam (comp cams) do u think that will work
Old Jan 2, 2006 | 08:29 PM
mkspeed26's Avatar
mkspeed26
it depends on what engine it is for
Old Jan 2, 2006 | 08:36 PM
Smokinrubber
its for 89 ford f250 block ..3.85 crank,h-beam rods,probe dish top piston ,pro comp 60cc aluminum heads stud girdle,,...i understand that my firing order is the same but im wondering how the computer is going to react to a 75mm tb and mass air and 30lb injectors ,msd igniton and coil,150amp powermaster, eldebrock intakes and water pump ..and what can i do to the computer...
Old Jan 2, 2006 | 10:08 PM
mkspeed26's Avatar
mkspeed26
oic. u can get it tuned to the combo at a dyno shop i believe
guitarman376
Sep 30, 2015 05:54 PM
LiquidDrink
Sep 29, 2015 10:06 AM
FoxGT
Jul 11, 2004 11:49 PM
Mustang88LXKid
Feb 29, 2004 08:01 PM
WNDSOR
Jan 30, 2004 09:47 AM
