V6 automatic THROTTLE
Old Jul 5, 2006 | 10:45 AM
StangFreak06's Avatar
StangFreak06
Default V6 automatic THROTTLE
Why does it seem that when i punch the gas from a stand still the car starts off slow for just under a second before it kicks in. i understand that this is partly expected from an automatic, but is there anything i can do to improve it?
Old Jul 5, 2006 | 10:48 AM
MHShockey30's Avatar
MHShockey30
Default RE: V6 automatic THROTTLE
Yes, you can get a Cold air intake and the SCT X-Cal 2, it will totally eliminate your throttle lag and the car will perform better than ever.
Old Jul 5, 2006 | 11:08 AM
StangFreak06
will that mess up the warrenty on the car?
Old Jul 5, 2006 | 11:12 AM
StangFreak06
ive been planning to install the afe intake at the end of this month, how will that help without a tune
Old Jul 5, 2006 | 11:35 AM
rygenstormlocke's Avatar
rygenstormlocke
ORIGINAL: StangFreak06
It helps some, I used to have it. But it dosent compare to a CAI/Tuner combo. You have to have a tuner tune out all the throttle management on our cars. As for warrenty, it will void the warrenty for the CAI, you can always put it back to stock tune before you take it in for service adn put the stock airbox on it. It takes less than 30 minutes to do the swap if you done it enough times.
Old Jul 6, 2006 | 01:47 AM
tomsa55's Avatar
tomsa55
Try recalibrating your throttle, turn key on, but don't start engine, just wait till all the sys check lights go off, about 5 to 8 seconds, then slowly press gas pedal all the way to the floor, this means you should have it floored in about 1 to 2 seconds. then let up, take foot off gas pedal, turn key off. Now start your engine, go for alittle drive, your throttle lag should be pretty much gone. This works on stock or after market tunes. This is how the pcu calibrates the rotery transducer (electronic throttle). This is why in the Owners Manual (yes you should read it) it tells you not to push down on the gas pedal when starting your engine. The pcu will get a false signal input and miss calibrate your throttle.
Old Jul 6, 2006 | 01:51 AM
Fizzie06's Avatar
Fizzie06
do you have to do it everytime you start your car
Old Jul 6, 2006 | 02:09 AM
tomsa55's Avatar
tomsa55
ORIGINAL: Fizzie06
No, just every once in a while if you notice the throttle is not responding like it should. I will not be the same as driving a direct link (throttle cable) type throttle. But try it, then just try and remember not to push down on the throttle when your starting the car, thats what throws it out of calibration.
Old Jul 6, 2006 | 03:28 AM
fitbikeco's Avatar
fitbikeco
haha na man just as long as you keep your stock airbox and save the stock tune if you use a tuner
just reinstall both and they wont notice
not that a cai tuner combo would ever mess up your engine ( i dont think )
Old Jul 6, 2006 | 10:06 AM
StangFreak06
thanks for the advice. ill try re callibrating on my lunch brake tomsa and ill post the results this afternoon.
