v6 twin turbo
RE: v6 twin turbo
wrong section, but even if you did post in the right section...the only aswer you would get is "no" lol
our engines arent very strong, so there is no used for a twin, just go single
RE: v6 twin turbo
wether its TT or just T .. boost is boost.. you make 10psi on TT or you make 10PSI on T. its all the same.. TT gets faster spool up and youcan get away with 2 smaller turbos, rather than 1 larger single
RE: v6 twin turbo
i would say that if you are thinkin about running a tt so you can run 30psi of boost then you would have a big problem with the internals in your motor
the block would be fine but the internals would fry
but if your not gonna even go close to that boost then a single turbo will do you just fine they can run 12 psi pretty easily
and from what i have herd you can turn the single up much higher than that but you would have to again chanage all your internals
RE: v6 twin turbo
if you make 10 psi on a single, or 10psi on a TT, boost is boost.. its just how fast you make that power is the difference.. 10psi on a twinturbo setup youll reach full boost at lower RPM compared to full boost at a higher RPM on a singleturbo
typically you have too small turbos, or one bigger turbo
