Turbo charger for the v6
RE: Turbo charger for the v6
ORIGINAL: rygenstormlocke
Its a Precision pt61, which I believe is a modified garret turbo. PH colaborated with percision, built the system around it, and the tune which is a majority of the R&D. The tube diameter, research, intake, intercooler and layout are PH design/mfg.
ORIGINAL: petepete
It is made by powerhouse
Why is that a dissapointment?
ORIGINAL: petepete
Wow theres something i didnt know. Kind of disappointing but oh well o_O
ORIGINAL: petepete
I dunno its just me i like to deal straight with main manufactures of a unit and if i want to do modifcations to the unit i like to do it myself. Like i would never buy a paxton supercharger because it is just a vortech you know what i mean? Nothing bad with it i just dont liek to
ORIGINAL: petepete
ORIGINAL: petepete
Well, garret is in a lot of turbo kits out there. They don't make a kit for the 4.0. What kind of modifications are you planning to make? Are you familiar with tuning cars?
ORIGINAL: petepete
Thanks for the info on the paxton i always been under the impression their thesame thing
twinturbomustang Date 8/19/2006 1:01:19 AM
mmmm 4000 thats alitlte stiff is there ANYTHING eltce??
ya the procharger is cheaper by $500 but it makes a lot less hp, and a lot less torque, and its all in the upper rpm range compared to the turbo.
The days of turbo companies makin turbo kits direct is long gone. Its all aftermarket shops using a certain turbo and fitting it to your cars application.
and what the hell is there to modify? If you want more boost, u change out the spring. ...... different wastegate, change the wastegate.... not a whole lot of "modyfing" to do.
If he makes custom turbokits, then have him make one. itd be the same thing as buyin it from powerhouse. He will start with a garrett/precision/t3/t4/t5 whatever turbo, and build around it. Its just how its done.
The Tail 38mm waste is also not made by Powerhouse and is regarded as a quality unit. So in essence the PowerHouse turbo system is built around the Precision PT 61 and the Tail 38mm wastegate both high quality components. This turbo system also has over a year of track time (+R&D) on it which has proven itself. This all makes this one very high quality turbo system for the 4.0 not to mention the support during install and after from Powehouse if needed.
