anyone done a big single exhaust?
RE: anyone done a big single exhaust?
ORIGINAL: fazm
well the other PC numbers are around 300-310rwhp on that boost, and thats on a dynojet.
ORIGINAL: stratjakt
Doesnt powerhouse have a v6 with 400 hp at the crank? I mean, it's possible, no?
Probably wouldn't last long on a non-built engine, I'd guess.
ORIGINAL: petepete
righ tyea if it was 320rwhp on a dynojet i would believe it easy but on a mustang dyno no
ORIGINAL: fazm
I like to mention on a Mustang dyno ( 10-12% correction I have even read 8%) this is just an estimate (correction) its not a exact science that is used, if you take 320 x 10% = 352 rwhp on a dyno jet, so if you add 1 psi ( around 20 +/- rwhp) to the ProCharger setup above 320rwhp@8.6psi (9.7) in the 5.0 article I could see 340+ rwhp (it would scale up esp on a centi S/C) on a dyno jet no problem and that would show about 320 on a Mustang Dyno (MD).
I think it is very possible I don't see why its so hard to believe for you guys, I hope he post (dyno info) because I want to look at the AFR#'s (along with how the AFR graph looks) and the TQ numbers on this setup.
ORIGINAL: armycook1981
justin tuned mine at 9 psi
292/312 were the final numbers... everything stock..
you arent going to see 20rwhp from 1psi for one
its going to be a lot closer to 10-12rwhp per psi, and the more psi, the less gain per psi due to inneficiencey of the power adder.
take 200rwhp
9psi gives roughly 100 more rwhp
thats bout 11rwhp per psi
take 200rwhp
ORIGINAL: fazm
its going to be a lot closer to 10-12rwhp per psi, and .
I also am not saying or mean to imply every single psi you go up you pick 20rwhp I agree with your statement on this, but I do believe its possible in the above scenario to hit 340rwhp and is possible to be at 340rwhp by the time you hit 10psi (9.7) from 8.6 psi.
I do believe a Procharger at 10psi with a good tune could hit 340rwhp in fact that was my goal if I went Procharger awhile ago.
I would also like to mention they only took the motor up to 5750 rpm on the 5.0 PC, going up higher esp on a centi S/C your going to pick up even more rwhp easly 5-10 rwhp right there with the same tune so we would also need to look at that on 87turbos rpm on the dyno sheet.
I also think its possible 340 rwhp could show up as 320rwhp on a MustangDyno.
