Alternative Auto Tune
I just purchased the C&L and xcal2 from alternative. The tuner came with the 87 and a 89 octane tune. Does anybody know if you can get a 91 or 93 tune from alternative?
He doesn't make them, what he suggests is bump up the timing 2 degrees in the first two rpm segments and fill up with 93. That is what I have been doing. This made my car run 14.50's in the quarter.
[IMG]local://upfiles/41550/4F71159778684E70890D514679473582.jpg[/IMG]
So you would advance the timing. I already have been running 93 octane anyway. How do you do this. Would i reinstall the 89 tune and when it asks to go to optional parmeters go in there??
ORIGINAL: chadlet
Ok I will try that. After doing so is that saved in the 89 tune or if i download the 89 tune again will i have to change the timing then also. Also if I wanted to fimr up the 2-3 shift what is 5 percent . Is it 5 percent or is it 5 percent more than the standard.
I don't know if you have to change it again, I would say if you return to stock then load the 89 back in, you will have to change the settings again. The 5% would be 5% more than it is set at in the 89 tune, which has increased shift pressure built into it. I have mine set at 25% increase on all shifts, but most folks don't like that kind of shift for around town driving.
ORIGINAL: chadlet
Ok thanks for the help.. How hard is that 25% on the transmission? How long have you ran it like that?
Sep 8, 2015 06:25 PM
Sep 1, 2015 08:16 PM
I beat on my car pretty bad.
