More boost question
Now, after posting that, I know Army will come out and post. But Army is prepared for what might happen as he's stated in other posts. MSP is also going this route, but he added all sorts of cooling to his ride, meth and other safety precautions he thinks will prevent any issues.
If I were to do it, I would do the 25 shot and window switch and a tune by one of the top tuners, that has experience with dual power adders.
in that case i think i will go with higher psi. this car has become my daily driver because im starting to like it more than my others =). What pulley size do you think would be the best? Also one other question a little off tangent here. Im running 3.73 gears. Now some have told me that a 3.55 would make it run faster. Somehow i think that it would be a 4.10 to get it to boost faster. Do you have any opinion on that?
Not sure on the pulley, ask Scrming. As for gears, you are a centri, 4.10s would be optimal to get you into boost from a dig, 3.73's would be my second choice. For 3.55's, they would probably be better for FI that builds boost early, like xchanger and turbo.
ORIGINAL: petepete
only once at irwindale 1/8 and my time was too bad to say :P i dont want to take it to the 1/4 till im sure i can hit a low 13
ORIGINAL: 28hopup
Hey PP,
Have you run that beast at the track yet???
Bill Jr.
ORIGINAL: petepete
yep definetely need the tuning. Kind of leaning towards more boost to always have it. I know the n2o will work fine but if the psi boost works just as good i would rather go that way.
Bill Jr.
As Rygen mentioned you should be in the low 13's with 10PSI... I ran 13.4's in 90+ degree heat with a 325 pound driver!
if you are running stock size tires (27 inches) 4.10s might be a bit much... also with the 4.10s traction might become an issue... I'm running 4.10s but:
1) I'm running a 28 inch tire (vs 27 inch)
2) I'm driving with my DR's on full time!
I also agree... for a DD I would just stick the 2.87 pulley on and get a nice safe tune... lower your shift points a bit... I just picked a 2.87 off e-bay for $35...
ORIGINAL: petepete
cool thanks for the info what did you type in the search for ebay. I put 2.8 pulley but nothing is coming up
