More boost question
Old 10-11-2006, 02:18 AM
petepete
petepete's Avatar
Default More boost question
So ive been thinking i either want to start spraying a 50 shot again or get like a 12-13 psi pulley. Wondering opinion on whats the safer route. Also what pulley to get if i want to get a higher boost on here. Any input would be appreciated
petepete is offline
Old 10-11-2006, 11:12 AM
28HopUp
MF Administrator
28HopUp's Avatar
Default RE: More boost question
PP,
I really don't have any answers to your questions, so I'll let more experienced folks chime in here. Since you have FI, I was wondering if you will need to have your tune adjusted to account for a 50-shot?
Let us know what you find out - I think having a 4.0L with multiple power adders would be sick!
Bill Jr.
28hopup
28HopUp is offline
Old 10-11-2006, 12:19 PM
StupidTodd
StupidTodd's Avatar
I'd think the 50 shot would be a bit safer than trying to up your boost.
The nitrous would act as a second stage intercooler, further cooling down your charge.
Either way, you may run out of fuel, and need a bigger pump or a booster of some nature. (if you don't have one already)
Be careful with the tuning.
StupidTodd is offline
Old 10-11-2006, 06:38 PM
petepete
petepete's Avatar
yep definetely need the tuning. Kind of leaning towards more boost to always have it. I know the n2o will work fine but if the psi boost works just as good i would rather go that way.
petepete is offline
Old 10-11-2006, 06:46 PM
28HopUp
MF Administrator
28HopUp's Avatar
ORIGINAL: petepete
Hey PP,
Have you run that beast at the track yet???
Bill Jr.
28HopUp is offline
Old 10-11-2006, 06:52 PM
petepete
petepete's Avatar
ORIGINAL: 28hopup
ORIGINAL: petepete
Hey PP,
Bill Jr.
only once at irwindale 1/8 and my time was too bad to say :P i dont want to take it to the 1/4 till im sure i can hit a low 13
petepete is offline
Old 10-11-2006, 08:54 PM
rygenstormlocke
rygenstormlocke's Avatar
The HP rating on the nozzle is not the same with FI. A 25HP shot is going to be more like 50-75, so I would stick with that. Also, I would invest in a window switch to make sure you only spray in the RPM prior to building boost, to get the TQ off the line. Dual power adders is still new to me, so I can't offer much....but Doug@Bama has done it and posted in this thread recently about it...
http://www.v6power.net/vb/showthread.php?t=28213
Have a read of it, he explains it much better than I could.
rygenstormlocke is offline
Old 10-11-2006, 08:55 PM
rygenstormlocke
ORIGINAL: petepete
ORIGINAL: 28hopup
ORIGINAL: petepete
Hey PP,
Bill Jr.
You don't need dual power adders to run a low 13 second run. Just takes practice.
Old 10-11-2006, 08:58 PM
petepete
petepete's Avatar
thanks for that info. So you think spray is a better idea than 12-13 psi?
petepete is offline
Old 10-11-2006, 09:13 PM
rygenstormlocke
ORIGINAL: petepete
thanks for that info. So you think n2o is a better idea than 12-13 psi?
For me, personally, NO. I think there are too many variables (moving parts, tuning parameters) to make it work safely with boost. For a weekend warrior or track car, hell yea. For a daily driver/weekend track car....I wouldn't do it. I would go with 12psi and a really safe tune.
Keep in mind on 10psi, you should be able to net a 13.3 or 13.4 run with practice.
Quick Reply: More boost question
