Hard starting
Ok I live in Michigan so its starting to get cold outside. It actually snowed the last two days. Not enough to stick but its cold. Anyway the last two days when my car is cold it starts hard. IT turns over and over then it sounds like you tried to start a car thats already running. Let off the key and try again it starts right up? What gives? I did in the last week bumb my timing up 2 degrees in the first two rpm ranges. Not sure if that is why it is hard to start or should I take it in to get looked at?
Scrimg I know you live in Saginaw have you ever had this problem? Also I will be in Ubly tommorrow from 12:00 till 2:00. I have to be at work at 3:00 in Piegon so i will have to leave early.
Dragonus18
Sep 9, 2015 01:21 AM
