How To:V6 to GT XPIPE CONV. W/All FORD PARTS
RE: How To:V6 to GT XPIPE CONV. W/All FORD PARTS
Keep in mind that they are showing how to remove the GT's H-pipe and replace it with an X. What you will be doing will be similar, but not exactly the same. Here are the other two pages:
[IMG]local://upfiles/53184/6596A5DB66AE4911A1F6E88520FFFCA4.jpg[/IMG]
[IMG]local://upfiles/53184/C8A0D750DEAB43D081BF9BD1C778B7B8.jpg[/IMG]
ORIGINAL: 68XR7
Thank you for your research, you made my mind up on what set-up to use as far as going duals[sm=redx.gif]Pipe..............what I can't understand is why someone replace the H-pipe for an X-pipe...............their must be an advantage to the X over the H...
I believe the X is more efficient at higher RPMs. You should go to Professor Wizards thread called:" crossover exhaust pipe explained... " I learned a lot from it. It is also the same thread that got me wondering about the harmonic buzz. When I got my system put in, I was relieved to find that this wasn't a problem, at least in my case. Check it out. It should answer some questions for you. Dave
ORIGINAL: afixer
my only concern is the welded x. i have had the duals for over a year now and actually had to remove them once already so i would highly recomend the clamps. my pipes dont leak and remember thats the way ford does it so whats the big problem with them. it bugs me that installers keep pushing this sp you have to go back to them if you have a prob. tranny ,driveshaft, gas tank all these things require the pipes removed although you can remove the driveshaft with some work. overall good job glad you like them i did mine in june of last year the car sounds great and really looks better from the rear with both in my opinion
Hey so do you think it would be better to buy an x-pipe and the mid pipe for the duals at lpc ford or have the shop fabricate the pipes?
Also, i got your pm and tried pm'in you back but it wouldnt let me for some reason, said you dont receive pm's
ORIGINAL: HurricaneStang
The scott talked to dave and ya he said he can give it to me for $84 but also if you get the ford parts the x-pipe is $130 so i dont know what way would be better for the price, i assume i should just get the pipe and the x. I just gotta find an x on ebay now.
Hi! 68XR7.
I had my dual exhaust installed on Saturday. It costs a little high, but I like it. I feel it shift better and quieter, especially at speed over 70 mph. The car is stronger. No drone. But, it still resonates at 1500 rpm like before with 1 exhaust.
I bought mid pipe $87.79, 2 brackets $101.68, X pipe $ 155.90, GT muffler take off $ 80. The prices are included shipping. I cut the bumper, mount 2 brackets. At first, the tip of the left muffler pointed to the center. I had to bend the 2 hangers to make it straight. The labor for installing is expensive ( $ 140 ). It is expensive maybe because I live at Silicon Valley, CA.
They cut the pipes after CAT and slided the X pipe in, then they slide midpipes in the X at other ends and weld them. I asked them to weld to make sure no leak.
Thank you for everything.
