Engine Squeeking
Old Feb 26, 2007 | 08:37 PM
mdlesk's Avatar
mdlesk
Default Engine Squeeking
This morning when I started my 05 Mustang is started idleing at 1500 RPM and it was squeeking really bad. It hasn't stopped since. I am really concerned. It has a little over 40,000 miles. It is coming from the belt at the front of the motor. But I can't tell what exactly it is, wether it's one of the tensioners or a pulley. I tried searching the forums but couldn't come up with anything. Has this happened to anyone else or does anyone know what it could be? This is my only car and I need to get it fixed as I am a full time college student and work everyday. Please Help!
Old Feb 26, 2007 | 10:01 PM
wolfey2k's Avatar
wolfey2k
Default RE: Engine Squeeking
Hi,
first thing. Check the belt for wear and stretching. You can do this by twisting the belt upside down so you can see the grooves of it and if thier are any cracks in it, time for replacement.
Next, pull the belt tensioner back to release pressure on the belt, not sure what wrench to use as I haven't had to do that yet since my car only has 4400 miles on it, then remove the belt and take it out to inspect more closely. Do the same thing only bend the belt backwards and look for cracks, chaffing, missing pieces of belt grooves etc. If you see any of this, replace the belt.
Then check all the pulleys. You may find a lose tensioner pulley, a lose idler pulley and or worse, a lose water pump pulley.You might finda stuck or sticky, 'hard to turn', A/C pump pulley or power steering pulley. If allchecks out fine,i.e. all pulleys spin freely and are not wobblingat all, then you just have a wornout serpentine belt and it's time for a new one.
Chances are that's all it is. Just a worn out belt. At 40K miles it sounds like it may have worn out prematurely but it's got to be close to time to replace it anyway.
If you can't figure out how to perform the above tests, take it to your local garage, hopefully someone you trust, and have it checked out. Beware ofone who tellsthat yousomething major is wrong. If they do, make them show you exactly what is wrong before you authorise the repair and make sure the price they give you is fair or seems fair to you as well of course ;-)..
Good luck!
Wolfey2k
Old Feb 26, 2007 | 10:10 PM
28HopUp's Avatar
28HopUp
MF Administrator
To stop squeeking from the under the hood, you gotta rememberto water and feed the hampster -
Old Feb 26, 2007 | 10:14 PM
Wisconsin 5.0's Avatar
Wisconsin 5.0
Dribble a little Armour All on the belt...see if the squeal goes away...simple check to see if its the belt or something else.
wolfey2k's Avatar
wolfey2k
ROFL SNORT!
Old Feb 26, 2007 | 11:32 PM
A_Sixer's Avatar
A_Sixer
Hi,
Great advice
Old Feb 27, 2007 | 03:20 PM
mdlesk's Avatar
mdlesk
I checked the belt and it doesn't seemed to be cracked. There are just a few grooves on the underneath side.
Old Feb 27, 2007 | 03:28 PM
wolfey2k's Avatar
wolfey2k
Does the belt seem loose? Does it flap up and down anywhere while the engine is running and making that noise?
If it does, then you have a pulley that's sticking or binding, i.e. it's resisting against turning smoothly.
Or it could be a bad idler pulley or tensioner pully or bad tensioner.
If you have the diagnostic know how, figure it out based on what I have explained.
If you don't then you'll have to take it to a qualified mechanic and have them diagnose and fix the problem.
Sorry I can't help more. I could if I was there to see it myself. No problem ;-).
Best of luck!
Wolfey2k
Old Feb 27, 2007 | 03:46 PM
mdlesk's Avatar
mdlesk
Thanks for the reply, it's not loose at all and I'm not about to look closer when it's running. I don't want to take it to a dealer so I'll try and find a reliable shop.
Old Feb 28, 2007 | 06:39 PM
wolfey2k's Avatar
wolfey2k
ORIGINAL: A_Sixer
Hi,
Great advice
Thanks!
