Driveshaft gain
Old Mar 25, 2007 | 05:37 PM
Nuke1's Avatar
Nuke1
Default Driveshaft gain
Has anybody had a dyno of before and after installing an aluminium driveshaft on the n/a 4.0. I know that there is no HP "gain" with the driveshaft swap but is there some more HP from the motor that are going to the rear wheels? Is it worth it?
Old Mar 25, 2007 | 11:55 PM
Denny Carlton's Avatar
Denny Carlton
Default RE: Driveshaft gain
Yes! I had a dyno done before and after I had the ph driveshift installed. No change in gain, but a hell of alot better on the highway at high speeds. Before I had the ph sd I had alot of vibration at high speeds from my ds and it seem to be a little lazy getting up there. But now its very smooth going from 80-110, just punch it and go's
But the gearshelp in that department, 3.73 and lose about 2-3hp
Maybe this will help you to see if the driveshift is for you.
mtgldr
Feb 3, 2024 09:00 PM
baddog671
Jul 26, 2016 01:20 PM
Boostaddict
2.3L Eco-Boost Tech
Nov 24, 2015 06:11 AM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
GLOCKer
Sep 28, 2015 07:36 AM
