JBA Single Axleback Ordered, Will It Be Drone Free?
Hey Guys, Well I ordered a JBA single axleback and it's on the way. Will it have the dreaded drone or should I weld on the 1lb bar first, that others swear by to stop drone? Thanks
RE: JBA Single Axleback Ordered, Will It Be Drone Free?
Hey Jay,
Since you told me you have it on and it sounds great, my answer is yes.
Glad you like it. Rained like a biotch today. Ipassed the leak test. Dry as a bone.
Later, DS
Later, DS
I have one installed on my 05 v6. It sounds good. From inside the car, it gives just enough sound to remind you that you are driving a sports car. From outside it sounds loud enough but not outrageous like the fart can on the imports. Quick tip on the install: unbolt the mounting hook that is attached to to the inner wall of the car ( between the muffler and the inside wall of the car). This will save you a lot of headaches! Trying to get three rubber mounts to go in at the same time while trying to line up the muffler inlet with the exhaust pipe was a nightmare!!!
mrappe
09-26-2015 10:16 AM
