PCM
Old May 11, 2007 | 05:02 PM
DelStang86's Avatar
DelStang86
Default PCM
has anyone considered relocating the pcm to the cabin (possibly tucked behind the glove compartment)? In extreme applications such as turbocharging/supercharging, underhood temperatures are much higher, so i thought the computer might be better off in the cabin. that, and it gives you a fair amount of room in the engine bay (if you were to shift the fuse box further in toward the headlight, or otherwise relocate it).
Old May 13, 2007 | 12:35 PM
DelStang86's Avatar
DelStang86
Default RE: PCM
anyone? it's a pretty simple concept... you know, kinda like how a computer runs better in an environment with a lower temperature.
Old May 13, 2007 | 08:57 PM
rygenstormlocke's Avatar
rygenstormlocke
Default RE: PCM
I don't know of anyone thats done it. It was designed for high heat, might be worth while in Arizona. Though the AZ guys havent reported PCM issues.
Old May 13, 2007 | 11:15 PM
fazm's Avatar
fazm
Default RE: PCM
106 degrees, 12psi, over 400rwhp and 450rwtq and no probs
Old May 14, 2007 | 12:38 AM
DelStang86's Avatar
DelStang86
Default RE: PCM
well, we don't know if this would provide any benefit or not, unless someone's actually willing to give it a shot, so how about we not shoot down ideas before they get tested out...
I'll be testing this out when I get back in the fall or so.
and besides, just because it's been running fine so far doesn't mean you won't have problems with it later. If you look at alot of drag setups, pcms are usually mounted on the passenger side in the cabin. gotta be a reason for that, right?
Old May 16, 2007 | 12:24 PM
Suijin's Avatar
Suijin
Default RE: PCM
Yeah...I'd say the reason most drag cars have them located on the passenger side is because they are running NON street legal setups...and the temperature inside the engine of a drag car far exceeds the temperature in the mustang. Most engine setups in a drag car are designed and worked on just for the 1/4 mile runs. Most of the time the engine needs repairs right after the run because they run so high. If you were pushin somethin crazy like 1500rwhp then I would consider relocating...but that is my own opinion...don't take it personally!
Old May 16, 2007 | 05:30 PM
DelStang86's Avatar
DelStang86
Default RE: PCM
well, the sportsman class ecotec cars run with the pcm inside... as do a number of cars i've been reading about in a book i have.. it just seems logical.. the casing can only provide for so much heat deflection.
Old May 16, 2007 | 08:46 PM
Suijin's Avatar
Suijin
Default RE: PCM
Well, I haven't heard any reports or anything related to the PCM breaking down with the addition of a Turbo/SuperCharger. But I guess it could be a possibility? I guess you could just go ahead and move it and air on the side of safety...I just haven't heard anything about the PCM being a problem with the heat SC's put out.
Old May 16, 2007 | 09:08 PM
DelStang86's Avatar
DelStang86
Default RE: PCM
yeah.. i was just saying, it might be a bit beneficial (and custom, custom never being a bad thing).. it cleans up the engine bay too... while you're doing it, you could run wires with a better conductor (yes, naysayers, i am aware that this could be costly).
Old May 17, 2007 | 08:07 PM
Suijin's Avatar
Suijin
Default RE: PCM
Yeah, and customization is the way everything is done these days...
