PCM
Old May 17, 2007 | 08:48 PM
DelStang86's Avatar
DelStang86
Default RE: PCM
apparently not.. everyone always gets the same mods. have you read the posts on this site yet?
Old May 17, 2007 | 09:39 PM
Suijin's Avatar
Suijin
Default RE: PCM
Yeah...but mods are mods and if you mod something from it's original state then it becomes customized...Even if all the mods are the same.
Old May 17, 2007 | 10:07 PM
takotruckin's Avatar
takotruckin
Default RE: PCM
have you messed with wiring before? i transplanted a 91 v6 into a baja bug, using the ford FI and DIS, and it was ALOT of electrical work.you are talking about OBII, (well, CAN actually) with alot more wires, many with very specific resistance values, its just not worth the risk or work, for no real gain, IMO
Old May 18, 2007 | 03:53 PM
DelStang86's Avatar
DelStang86
Default RE: PCM
I'm good with wiring. Thanks for being so critical guys
Old May 24, 2007 | 01:05 AM
pat6674u's Avatar
pat6674u
Default RE: PCM
Critical is in the eye of the beholder. The PCM is heavily shielded and likely been put through the ringer with regards to heat tests. The only question everyone asked is what is the value in it? Will this mod equate into improved performance? Is the amount of time, money and frustration worth the expected benefit? I say give the mod a try, document your findings and let us know the results.
djbigskrilla
Sep 20, 2022 01:04 AM
mstahoo
SVT Forums
Aug 19, 2021 09:15 PM
bryan616fl
Jan 25, 2019 09:07 PM
StangMuscle
Aug 12, 2015 07:27 AM
HIS S-197
Aug 10, 2015 05:47 PM
