Old Oct 23, 2015, 03:20 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Ford Mustang Powertrain Guides
Print Wikipost
Installing Fuel Filter, with pics!
Old Feb 20, 2010 | 04:04 PM
  #61
157dB's Avatar
157dB
Cut & Paste Expert
Originally Posted by robs
Phew... Thanks for the link... Some moron tried to pry out the little clip (like on every other car I've... er, the moron ever had)...
So you push the green clips IN ...
I am at 30K miles and its going to be done first warm day round here....
Thanks for the write-up.
It seems so simple that the stealership is getting $40+ to do this
just for the labor?
<landon.moss>
Nice pic of the side by side stang and chally
I love mine as well....
Old Feb 22, 2010 | 08:46 PM
  #62
157dB's Avatar
157dB
Cut & Paste Expert
Originally Posted by Fyrewalker
Hi, I am a new owner of a 2005 Mustang V6, bought it with 18k miles and since I didn't know
much about the history of maintenance I decided to change all the fluids and filters. So, today
it was the fuel filter. This is a VERY simple job that anyone that knows "lefty loosey, righty tighty" can accomplish. I included some pics.
1. remove the fuel pump fuse which is under the hood, in the fuse box on the passenger side, it is the fuse that is numbered 21 (page 165 in your owners manual)
Page 165 in the 06 manual.
Page 171 in the 05 manual.
Page 181 in the 07 manual.
Actually the F21 is the 'Fuel Pump Micro Relay. The Fuel Pump
Fuse is F41 as stated in the owners manual and the workshop manual
in reference to fuel pressure releasing procedures.
1a. Turn the ignition and try to start the car, it shouldn't. Removing the fuse and trying to start will use up the gasoline that is
in the fuel line and because the fuel pump fuse is removed, no more gasoline will be introduced into the fuel line you are
going to be separating. This step makes it so when you do remove the fuel filter there will be very little gasoline left in the
fuel line (less of a mess).
According to the Workshop Manual, the engine should start using
any residual pressure to feed the fuel to the injectors with the
Fuel Pump fuse pulled. The engine does not suck the fuel and seeing
how the fuel pump is in the fuel tank, all you are doing is releasing
any residual pressures present in the fuel system prior to removing
the fuel filter so fuel does not spray on you. So there will be in effect
a full fuel system but just not under pressure. So there is 100% fuel
left in the system but not under pressure.
I added a few very strong rare earth magnets out of a HDD
to the inlet side of my fuel filter to trap any suspended metal
or rust particals before it reaches/clogs the filter medium...
Attached Thumbnails  Installing Fuel Filter, with pics!-fuelfiltermagnets.jpg
Old Nov 28, 2010 | 02:46 PM
  #63
Cuzzo's Avatar
Cuzzo
Thanks for the tutorial
Old Nov 28, 2010 | 10:34 PM
  #64
Blue07V6's Avatar
Blue07V6
Hmm, guess I should change mine. I have 73,000 miles on my car. Never thought to change it. . . . . .
Old Jul 18, 2011 | 08:29 AM
  #65
07heat's Avatar
07heat
wish the pix still worked... gonna tackle this this weekend!
Old Jul 19, 2011 | 05:54 PM
  #66
IndecisiveS197's Avatar
IndecisiveS197
Its really straight forward. Just get under the car right under the Driver's seat and you'll see everything. I did this when I first got the car and will be doing it again soon. I would have something ready like an ice cream bucket or something ready to catch the gasoline that comes out though. It's not much but having it all over the ground kinda sucks
Old Jul 25, 2011 | 12:37 AM
  #67
IvanRad's Avatar
IvanRad
link is dead can u repost?
Old Jul 25, 2011 | 12:15 PM
  #68
07heat's Avatar
07heat
Just got finished chaning my Fuel Filter. Super Easy!
used the instuctions from www.americanmuscle.com
Old Jan 7, 2012 | 05:08 PM
  #69
bakerjd's Avatar
bakerjd
Where did you guys dispose of the old filter? I'm on the fence with trashing it due to the gasoline.
Old Jan 8, 2012 | 10:37 AM
  #70
MustangFirstCar's Avatar
MustangFirstCar
Neighbor's trashcan?
