7.5 to 8.8 swap
RE: 7.5 to 8.8 swap
i can't stress this enough. switching to a ford T-lok doesn't strengthen the 7.5rear. it is actually weaker than the stock Open rear as the 2 housings are basically the same casting but the T-lok is opened up to accept the clutchpacks.
i have seen alot of them break and the clutches wear out fast.
if you want a 7.5 that will be stronger than a stock 8.8 then get a Detroit truetrac. you can alkways add a TA girdle too with a panhard relocation kit
truetrac,girdle and your good for 500rwhp except the axles> Alloy USA axles from summit are a good option for those running a poweradder
the T-lok will survive longer in an auto but they are known to break on hard launches on 5spds at just 200rwhp/200ftlbs torque.
my old t-lok was warped and had stress cracks in the casting and the spyders were loose and had some pretty good chunks out of them.
RE: 7.5 to 8.8 swap
ORIGINAL: danbevsv6rumbler
so you're saying the ford racing t-lock on v6mustangstuff.com wouldn't be worth my time? i'm also debating the 8.8 swap or the 7.5 rebuild...
you might be lucky with a while and the tlok might last a little while, but you could just throw a detroit in it and not worry about it
also ive blown up 8.8s on stock MACH 1 power
RE: 7.5 to 8.8 swap
I have a 8.8 from my 06 GT just sitting on my garage floor. It had about 4000 miles when I put in the Currie 9". Also has stock driveshaft attached. Car was a manual so should have 3.55 gears which was stock for that year. Anybody want it?
RE: 7.5 to 8.8 swap
Wish that I was ready to make the swap Forensic - I've been thinking that when I go with the 8.8 I want the 3.55's along with my supercharger. This isn't the right time of the year for me to justify to my wife spendingcash on my car though!
RE: 7.5 to 8.8 swap
Sorry for delay in responding blackstang14.
$350 for 8.8 rearend, 3.55 gears, and stock driveshaft still attached. My whole transmisson is in Long Island right now being upgraded. UPS came pick it up and took it away. Two days later, it's in Bay Shore.
